주요 콘텐츠로 건너뛰기
Akai MPD18 Sensitivity Adjustment technique
필요한 것
  1. Akai MPD18 Sensitivity Adjustment technique, Take out the fader: 1 단계, 이미지 1개 중 1개
    • Begin disassembling the device. First, you need to remove the fader by pulling it at yourself using two fingers.
  2. Akai MPD18 Sensitivity Adjustment technique: 2 단계, 이미지 1개 중 1개
    • Remove all screws at back side using screwdriver.
  3. Akai MPD18 Sensitivity Adjustment technique: 3 단계, 이미지 1개 중 1개
    • Pull the upper case at yourself from non-USB-socket side and remove it.
  4. Akai MPD18 Sensitivity Adjustment technique: 4 단계, 이미지 2개 중 1개 Akai MPD18 Sensitivity Adjustment technique: 4 단계, 이미지 2개 중 2개
    • Pull the rubber pad at yourself so you can see the capacity elements pad. Remove all the screws that holding this pad and PCB (not all shown in photo).
    • Accurately open and disconnect the pad connector.
  5. Akai MPD18 Sensitivity Adjustment technique: 5 단계, 이미지 1개 중 1개
    • Remove the steel pads and now you can see the PCB. I recommend to remove it too for avoid damaging plastic during the solder.
  6. Akai MPD18 Sensitivity Adjustment technique: 6 단계, 이미지 2개 중 1개 Akai MPD18 Sensitivity Adjustment technique: 6 단계, 이미지 2개 중 2개
    • Now use your solder iron for changing velocity of the pads.
    • To inscrease velocity of four pads group you need to change the BIAS resistor near the operation amplifier (LMV324M) IC.
    • The higher resistor you will take - more sensivity you will get. The default resistor is 27K so you have to take replacement HIGHER than this value. For my pads it worked at 100K and 56K (because there's a difference on sensivity).
    • The amplification coefficient equals (1 + R2/R1). Default R2 = 27K and R1 = 10K so it equals 3.7. If you're using 100K resistor it equals 11.
    • (If you'll remove this resistor, then sensivity will increase very high so it will react even if you're clap near the sensors, so choose it reasonably).
    • To change sensivity on generic pad you have to solder the little capacitor between reference line and output line of this pad. The capacity must be relativly high. At my pads it worked at 68n-100n. Lower capacity will not work, higher will cause phantom clicking.
    • That all! Now you can assemble it and test.
결론
To assemble device do the instructions backward (of course without soldering again.)
작성자
3다른 기여자 명과 함께
pikudo
회원 가입일: 06/14/19
1,035 평판
안내서 5개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 8
지난 30일: 21
전체 시간: 1,141
