주요 콘텐츠로 건너뛰기
Akai MPK25 Beat Pad Replacement
필요한 것
  1. Akai MPK25 Beat Pad Replacement, Face Plate: 1 단계, 이미지 1개 중 1개
    • Remove all the selector knob covers by pulling them off.
  2. Akai MPK25 Beat Pad Replacement: 2 단계, 이미지 1개 중 1개
    • Using needle nose pliers, remove the washers from the four corner selector knobs.
  3. Akai MPK25 Beat Pad Replacement: 3 단계, 이미지 1개 중 1개
    • Flip the device over. Using a Philips #2 screw driver, remove the fourteen 10.3 mm black screws holding the back panel in place.
  4. Akai MPK25 Beat Pad Replacement: 4 단계, 이미지 3개 중 1개 Akai MPK25 Beat Pad Replacement: 4 단계, 이미지 3개 중 2개 Akai MPK25 Beat Pad Replacement: 4 단계, 이미지 3개 중 3개
    • Carefully flip the device to the front making sure you secure the face plate and the chassis together.
    • Please use care in following the step above to avoid ripping the ribbon cables connecting the two sides.
  5. Akai MPK25 Beat Pad Replacement: 5 단계, 이미지 3개 중 1개 Akai MPK25 Beat Pad Replacement: 5 단계, 이미지 3개 중 2개 Akai MPK25 Beat Pad Replacement: 5 단계, 이미지 3개 중 3개
    • Rotate the device 180 degrees and carefully remove the face plate by slightly lifting the screen side towards you and then sliding the bottom out from under the keys.
    • Use care when doing the step above so that the ribbon connectors which connect the top of the chassis to the top of the face plate are not damaged.
  6. Akai MPK25 Beat Pad Replacement, Beat Pad: 6 단계, 이미지 1개 중 1개
    • Using a Phillips #2 screwdriver, remove the thirteen 9.8 mm silver screws holding the mother board to the face plate.
  7. Akai MPK25 Beat Pad Replacement: 7 단계, 이미지 1개 중 1개
    • Using a Phillips #2 screwdriver, remove the four 9.8mm screws holding in the base of the beat pad.
  8. Akai MPK25 Beat Pad Replacement: 8 단계, 이미지 2개 중 1개 Akai MPK25 Beat Pad Replacement: 8 단계, 이미지 2개 중 2개
    • Slightly lift the mother board near the edge of the beat pads and wiggle the beat pad ribbon connector free.
  9. Akai MPK25 Beat Pad Replacement: 9 단계, 이미지 2개 중 1개 Akai MPK25 Beat Pad Replacement: 9 단계, 이미지 2개 중 2개
    • Remove the beat pad sensor from the face plate.
결론
작성자
6다른 기여자 명과 함께
Serbinder Singh
회원 가입일: 01/30/13
81 평판
안내서 3개를 작성함
Cal Poly, Team 20-6, Maness Winter 2013 Cal Poly, Team 20-6, Maness Winter 2013 회원
CPSU-MANESS-W13S20G6
5 회원들
안내서 6개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 10
전체 시간: 4,276
