주요 콘텐츠로 건너뛰기
Akai MPK25 LCD Replacement
필요한 것
  1. Akai MPK25 LCD Replacement, Face Plate: 1 단계, 이미지 1/1
    • Remove all the selector knob covers by pulling them off.
  2. Akai MPK25 LCD Replacement: 2 단계, 이미지 1/1
    • Using needle nose pliers, remove the washers from the four corner selector knobs.
  3. Akai MPK25 LCD Replacement: 3 단계, 이미지 1/1
    • Flip the device over. Using a Philips #2 screw driver, remove the fourteen 10.3 mm black screws holding the back panel in place.
  4. Akai MPK25 LCD Replacement: 4 단계, 이미지 1/3 Akai MPK25 LCD Replacement: 4 단계, 이미지 2/3 Akai MPK25 LCD Replacement: 4 단계, 이미지 3/3
    • Carefully flip the device to the front making sure you secure the face plate and the chassis together.
    • Please use care in following the step above to avoid ripping the ribbon cables connecting the two sides.
  5. Akai MPK25 LCD Replacement: 5 단계, 이미지 1/3 Akai MPK25 LCD Replacement: 5 단계, 이미지 2/3 Akai MPK25 LCD Replacement: 5 단계, 이미지 3/3
    • Rotate the device 180 degrees and carefully remove the face plate by slightly lifting the screen side towards you and then sliding the bottom out from under the keys.
    • Use care when doing the step above so that the ribbon connectors which connect the top of the chassis to the top of the face plate are not damaged.
  6. Akai MPK25 LCD Replacement, LCD: 6 단계, 이미지 1/1
    • Using a Phillips #00 screwdriver, remove the four 8.9 mm screws.
  7. Akai MPK25 LCD Replacement: 7 단계, 이미지 1/1
    • Using a Phillips #2 screwdriver, remove the one 9.8mm screw holding down the ground wire.
  8. Akai MPK25 LCD Replacement: 8 단계, 이미지 1/2 Akai MPK25 LCD Replacement: 8 단계, 이미지 2/2
    • Using two plastic opening tools, slide the black locking mechanism on the ZIF connector towards you. This will remove the ribbon cable connecting the motherboard to the screen.
  9. Akai MPK25 LCD Replacement: 9 단계, 이미지 1/1
    • Lift the screen from either side, removing it from the board.
결론
To reassemble the display, follow these instructions in reverse order.
다른 2명이 해당 안내서를 완성하였습니다.
Will Saba
회원 가입일: 01/11/13
391 평판
안내서 2개 작성하였습니다
Cal Poly, Team 20-6, Maness Winter 2013 Cal Poly, Team 20-6, Maness Winter 2013 회원
CPSU-MANESS-W13S20G6
5 회원들
안내서 6개 작성하였습니다
One Comment
Where can I find a new ribbon?
Wise Professor - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 9
전체 시간: 1,951
