주요 콘텐츠로 건너뛰기
Akai MPK25 Volume Knob / Pitch Bender Replacement
필요한 것
  1. Akai MPK25 Volume Knob / Pitch Bender Replacement, Face Plate: 1 단계, 이미지 1/1
    • Remove all the selector knob covers by pulling them off.
  2. Akai MPK25 Volume Knob / Pitch Bender Replacement: 2 단계, 이미지 1/1
    • Using needle nose pliers, remove the washers from the four corner selector knobs.
  3. Akai MPK25 Volume Knob / Pitch Bender Replacement: 3 단계, 이미지 1/1
    • Flip the device over. Using a Philips #2 screw driver, remove the fourteen 10.3 mm black screws holding the back panel in place.
  4. Akai MPK25 Volume Knob / Pitch Bender Replacement: 4 단계, 이미지 1/3 Akai MPK25 Volume Knob / Pitch Bender Replacement: 4 단계, 이미지 2/3 Akai MPK25 Volume Knob / Pitch Bender Replacement: 4 단계, 이미지 3/3
    • Carefully flip the device to the front making sure you secure the face plate and the chassis together.
    • Please use care in following the step above to avoid ripping the ribbon cables connecting the two sides.
  5. Akai MPK25 Volume Knob / Pitch Bender Replacement: 5 단계, 이미지 1/3 Akai MPK25 Volume Knob / Pitch Bender Replacement: 5 단계, 이미지 2/3 Akai MPK25 Volume Knob / Pitch Bender Replacement: 5 단계, 이미지 3/3
    • Rotate the device 180 degrees and carefully remove the face plate by slightly lifting the screen side towards you and then sliding the bottom out from under the keys.
    • Use care when doing the step above so that the ribbon connectors which connect the top of the chassis to the top of the face plate are not damaged.
  6. Akai MPK25 Volume Knob / Pitch Bender Replacement, Volume Knob / Pitch Bender: 6 단계, 이미지 1/1
    • Rotate the device 180 degrees, so that the motherboard is closest to you.
    • Take caution to not damage the ribbon cable connecting the face plate to the chassis.
    • Remove the ribbon cable connecting the knobs to the mother board by gently wiggling and pulling it away from the motherboard.
  7. Akai MPK25 Volume Knob / Pitch Bender Replacement: 7 단계, 이미지 1/2 Akai MPK25 Volume Knob / Pitch Bender Replacement: 7 단계, 이미지 2/2
    • Using a Phillips #2 screwdriver, remove the four 9.5 mm silver screws holding the knobs to the face plate.
결론
다른 5명이 해당 안내서를 완성하였습니다.
Serbinder Singh
회원 가입일: 01/30/13
81 평판
안내서 3개 작성하였습니다
Cal Poly, Team 20-6, Maness Winter 2013 Cal Poly, Team 20-6, Maness Winter 2013 회원
CPSU-MANESS-W13S20G6
5 회원들
안내서 6개 작성하였습니다
0 댓글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 14
전체 시간: 2,448
