주요 콘텐츠로 건너뛰기
Akai Retro Boom CD player model CE2200 Speaker Replacement
필요한 것
  1. Akai Retro Boom CD player model CE2200 Speaker Replacement, Speaker: 1 단계, 이미지 3개 중 1개 Akai Retro Boom CD player model CE2200 Speaker Replacement, Speaker: 1 단계, 이미지 3개 중 2개 Akai Retro Boom CD player model CE2200 Speaker Replacement, Speaker: 1 단계, 이미지 3개 중 3개
    • Remove the batteries located under the radio by sliding open the removable panel.
  2. Akai Retro Boom CD player model CE2200 Speaker Replacement: 2 단계, 이미지 3개 중 1개 Akai Retro Boom CD player model CE2200 Speaker Replacement: 2 단계, 이미지 3개 중 2개 Akai Retro Boom CD player model CE2200 Speaker Replacement: 2 단계, 이미지 3개 중 3개
    • Use a six inch Phillips #2 screwdriver to remove the screws that hold the clamshell body together.
    • There will be six (6) screws at the bottom of the speaker, one (1) screw in the CD player, and two (2) under the battery panel. A total of nine (9) screws.
    • Each screw is 12.7 millimeters.
  3. Akai Retro Boom CD player model CE2200 Speaker Replacement: 3 단계, 이미지 3개 중 1개 Akai Retro Boom CD player model CE2200 Speaker Replacement: 3 단계, 이미지 3개 중 2개 Akai Retro Boom CD player model CE2200 Speaker Replacement: 3 단계, 이미지 3개 중 3개
    • Use the plastic spudger or the Jimmy to gently pry open the plastic shell halves from each other.
    • The red boxes highlight the speakers you are replacing.
    • Be careful of loose wiring when prying the halves open.
  4. Akai Retro Boom CD player model CE2200 Speaker Replacement: 4 단계, 이미지 2개 중 1개 Akai Retro Boom CD player model CE2200 Speaker Replacement: 4 단계, 이미지 2개 중 2개
    • Unplug the small red connector from the circuit board.
    • Be firm with your pinch and pull gently.
  5. Akai Retro Boom CD player model CE2200 Speaker Replacement: 5 단계, 이미지 2개 중 1개 Akai Retro Boom CD player model CE2200 Speaker Replacement: 5 단계, 이미지 2개 중 2개
    • Carefully remove the speakers from their placeholders by lifting each speaker up.
    • Set removed speakers aside and recycle them later.
  6. Akai Retro Boom CD player model CE2200 Speaker Replacement: 6 단계, 이미지 2개 중 1개 Akai Retro Boom CD player model CE2200 Speaker Replacement: 6 단계, 이미지 2개 중 2개
    • Insert new speakers where the old ones were located
    • Then connect the new speakers to the circuit board.
결승점
다른 2명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Charlotte Kong
회원 가입일: 09/30/19
148 평판
안내서 1개를 작성함
CSU Fullerton, Team S1-G2, Bruce Fall 2019 CSU Fullerton, Team S1-G2, Bruce Fall 2019 회원
CSUF-BRUCE-F19S1G2
4 회원들
안내서 1개 작성
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 5
지난 30일: 25
전체 시간: 492
