주요 콘텐츠로 건너뛰기
Akaso EK7000 4K Battery Replacement
  1. Akaso EK7000 4K Battery Replacement, Battery: 1 단계, 이미지 1/2 Akaso EK7000 4K Battery Replacement, Battery: 1 단계, 이미지 2/2
    • Locate the battery cover at the bottom of the camera. Use your fingers to gently pry open the battery cover.
  2. Akaso EK7000 4K Battery Replacement: 2 단계, 이미지 1/2 Akaso EK7000 4K Battery Replacement: 2 단계, 이미지 2/2
    • Locate the small plastic flap attached to the battery. Pull the battery out towards you.
결론
다른 6명이 해당 안내서를 완성하였습니다.
Annie Sun
회원 가입일: 02/05/19
436 평판
안내서 3개 작성하였습니다
UC Davis, Team S20-G2, Lore Winter 2019 UC Davis, Team S20-G2, Lore Winter 2019 회원
UCD-LORE-W19S20G2
3 회원들
안내서 4개 작성하였습니다
댓글 2개
Thank you for the help actclly needed that help
Charisma Broughton - 답글
I’ve been using my Akaso EK7000 Pro as a dashcam, I removed the battery and plugged the camera into the cars cigar lighter, now when I insert the battery the cover won’t go back on.
The battery will push down into place but when I let go to put the cover on the battery moves up and the cover is about one tenth of one millimetre too high to fit.
The camera does get quite warm when in use and I suspect the plastic of the battery chamber has slightly distorted preventing the battery going fully into it and allowing the cover to be put into place.
Do you have any suggestions how I can resolve this issue?
Glynn Sole - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 9
30일 전: 52
전체 시간: 4,608
