주요 콘텐츠로 건너뛰기
Akaso EK7000 4K Microphone Replacement
필요한 것
  1. Akaso EK7000 4K Microphone Replacement, Battery: 1 단계, 이미지 1/2 Akaso EK7000 4K Microphone Replacement, Battery: 1 단계, 이미지 2/2
    • Locate the battery cover at the bottom of the camera. Use your fingers to gently pry open the battery cover.
  2. Akaso EK7000 4K Microphone Replacement: 2 단계, 이미지 1/2 Akaso EK7000 4K Microphone Replacement: 2 단계, 이미지 2/2
    • Locate the small plastic flap attached to the battery. Pull the battery out towards you.
  3. Akaso EK7000 4K Microphone Replacement, Front Panel: 3 단계, 이미지 1/2 Akaso EK7000 4K Microphone Replacement, Front Panel: 3 단계, 이미지 2/2
    • Using the metal spudger, gently pry open the front panel from the exposed battery cartridge.
  4. Akaso EK7000 4K Microphone Replacement: 4 단계, 이미지 1/2 Akaso EK7000 4K Microphone Replacement: 4 단계, 이미지 2/2
    • Remove the rest of front panel with your fingers or with assistance from the spudger.
  5. Akaso EK7000 4K Microphone Replacement, Microphone: 5 단계, 이미지 1/2 Akaso EK7000 4K Microphone Replacement, Microphone: 5 단계, 이미지 2/2
    • After removing the front panel, make sure that the battery is also removed from the camera battery cartridge to continue.
  6. Akaso EK7000 4K Microphone Replacement: 6 단계, 이미지 1/2 Akaso EK7000 4K Microphone Replacement: 6 단계, 이미지 2/2
    • When observing the camera plate under the front panel, notice that there are four screws holding the camera plate in place.
    • Use a Phillips #000 screwdriver to remove all four screws.
  7. Akaso EK7000 4K Microphone Replacement: 7 단계, 이미지 1/2 Akaso EK7000 4K Microphone Replacement: 7 단계, 이미지 2/2
    • Insert a thumb into the battery cartridge and gently push up. Be careful as not to pull apart or break any of the wiring that connects the front plate to the LED screen. The microphone will be on the left bottom corner of the front panel.
    • Gently pull out the microphone. Now you can re-adjust or replace the microphone.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Katrina Shi
회원 가입일: 02/06/19
166 평판
안내서 1개 작성함
UC Davis, Team S20-G2, Lore Winter 2019 UC Davis, Team S20-G2, Lore Winter 2019 회원
UCD-LORE-W19S20G2
3 회원들
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 40
전체 시간: 2,811
