주요 콘텐츠로 건너뛰기
Akko MOD 007 v2 Keyboard Switch Replacement
필요한 것
  1. Akko MOD 007 v2 Keyboard Switch Replacement, Keyboard Switch: 1 단계, 이미지 2개 중 1개 Akko MOD 007 v2 Keyboard Switch Replacement, Keyboard Switch: 1 단계, 이미지 2개 중 2개
    • Unplug the USB-C cable.
  2. Akko MOD 007 v2 Keyboard Switch Replacement: 2 단계, 이미지 2개 중 1개 Akko MOD 007 v2 Keyboard Switch Replacement: 2 단계, 이미지 2개 중 2개
    • Flip the keyboard over so the backside is facing up.
    • Remove the three longer 20.2 mm screws using the T5 Torx screwdriver.
    • Remove the three 8 mm screws using the T5 Torx screwdriver.
  3. Akko MOD 007 v2 Keyboard Switch Replacement: 3 단계, 이미지 2개 중 1개 Akko MOD 007 v2 Keyboard Switch Replacement: 3 단계, 이미지 2개 중 2개
    • Pull the front and back case apart.
    • If your keyboard is dirty, you’ll want to clean it before continuing. Use compressed air or a brush.
  4. Akko MOD 007 v2 Keyboard Switch Replacement: 4 단계, 이미지 2개 중 1개 Akko MOD 007 v2 Keyboard Switch Replacement: 4 단계, 이미지 2개 중 2개
    • Insert the keycap puller horizontally on the keycap and pull up.
    • Excessive force may break the tool or keycaps so don't yank the keycap up.
  5. Akko MOD 007 v2 Keyboard Switch Replacement: 5 단계, 이미지 2개 중 1개 Akko MOD 007 v2 Keyboard Switch Replacement: 5 단계, 이미지 2개 중 2개
    • Insert the switch puller vertically in the switch tabs and gently pull up.
  6. Akko MOD 007 v2 Keyboard Switch Replacement: 6 단계, 이미지 3개 중 1개 Akko MOD 007 v2 Keyboard Switch Replacement: 6 단계, 이미지 3개 중 2개 Akko MOD 007 v2 Keyboard Switch Replacement: 6 단계, 이미지 3개 중 3개
    • Orientate the new switch to align the pins to the board's sockets.
    • Push the switch down into the sockets.
    • Make sure the pins are aligned to sockets, as misalignment will cause the switch to be faulty.
결론
Test the switch by opening a keyboard tester website, like 'keyboardtester.com,' and press the key to see if it activates.
작성자
2다른 기여자 명과 함께
Farhan
회원 가입일: 09/19/22
133 평판
안내서 1개를 작성함
York University, Team A-2, Morris Fall 2022 York University, Team A-2, Morris Fall 2022 회원
YORK-MORRIS-F22SAG2
2 회원들
안내서 1개 작성
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 5
지난 7일: 12
지난 30일: 50
전체 시간: 1,909
