소개
If you need to replace the antenna in your Alcatel IdealXCITE, you should use the following guide.
필요한 것
Place your finger in the small notch on the left corner of the phone.
Use your finger to gently pull up on the back cover where the notch is located.
Gently pull up on the back cover, working around the phone.
Remove the cover from the phone, and set it aside for later installation.
거의 끝나갑니다!
결론
