주요 콘텐츠로 건너뛰기
Alcatel IdealXCITE Rear Speaker Replacement
필요한 것
  1. Alcatel IdealXCITE Rear Speaker Replacement, Battery: 1 단계, 이미지 1/3 Alcatel IdealXCITE Rear Speaker Replacement, Battery: 1 단계, 이미지 2/3 Alcatel IdealXCITE Rear Speaker Replacement, Battery: 1 단계, 이미지 3/3
    • Place your finger in the small notch on the left corner of the phone.
    • Use your finger to gently pull up on the back cover where the notch is located.
    • Gently pull up on the back cover, working around the phone.
    • Remove the cover from the phone, and set it aside for later installation.
  2. Alcatel IdealXCITE Rear Speaker Replacement: 2 단계, 이미지 1/3 Alcatel IdealXCITE Rear Speaker Replacement: 2 단계, 이미지 2/3 Alcatel IdealXCITE Rear Speaker Replacement: 2 단계, 이미지 3/3
    • Place your thumb in the small notch between the battery and the phone.
    • Use your thumb to gently pry the battery up at the notch, releasing it from the phone.
    • Take note of the contacts in the phone and on the battery for reinstallation.
  3. Alcatel IdealXCITE Rear Speaker Replacement, Antenna: 3 단계, 이미지 1/2 Alcatel IdealXCITE Rear Speaker Replacement, Antenna: 3 단계, 이미지 2/2
    • Remove the four 4mm PH00 screws.
  4. Alcatel IdealXCITE Rear Speaker Replacement: 4 단계, 이미지 1/3 Alcatel IdealXCITE Rear Speaker Replacement: 4 단계, 이미지 2/3 Alcatel IdealXCITE Rear Speaker Replacement: 4 단계, 이미지 3/3
    • Using a spudger, pry upwards in the indentation on the bottom right corner of the phone.
    • Work the tool gently around the antenna to release it.
  5. Alcatel IdealXCITE Rear Speaker Replacement, Rear Speaker: 5 단계, 이미지 1/3 Alcatel IdealXCITE Rear Speaker Replacement, Rear Speaker: 5 단계, 이미지 2/3 Alcatel IdealXCITE Rear Speaker Replacement, Rear Speaker: 5 단계, 이미지 3/3
    • Remove the three 4mm PH00 screws holding the WiFi/GPS antenna in.
    • Gently pry the WiFi/GPS antenna out using a Jimmy and set aside.
  6. Alcatel IdealXCITE Rear Speaker Replacement: 6 단계, 이미지 1/2 Alcatel IdealXCITE Rear Speaker Replacement: 6 단계, 이미지 2/2
    • Remove the three remaining 4mm PH00 screws.
    • Remove the two 3mm PH00 screws.
  7. Alcatel IdealXCITE Rear Speaker Replacement: 7 단계, 이미지 1/3 Alcatel IdealXCITE Rear Speaker Replacement: 7 단계, 이미지 2/3 Alcatel IdealXCITE Rear Speaker Replacement: 7 단계, 이미지 3/3
    • Using a spudger and an iFixit opening pick, pry the midframe up.
  8. Alcatel IdealXCITE Rear Speaker Replacement: 8 단계, 이미지 1/3 Alcatel IdealXCITE Rear Speaker Replacement: 8 단계, 이미지 2/3 Alcatel IdealXCITE Rear Speaker Replacement: 8 단계, 이미지 3/3
    • Pry gently between the rear case and speaker using an iFixit opening pick.
    • Reapply adhesive to the new speaker when reassembling the phone.
결론
Franklin Froehlich
회원 가입일: 03/07/19
427 평판
안내서 3개 작성하였습니다
Casper College, Team S1-G2, Lareau Spring 2019 Casper College, Team S1-G2, Lareau Spring 2019 회원
CASC-LAREAU-S19S1G2
4 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 14
전체 시간: 314
