소개
If you need to replace the rear speaker in your Alcatel IdealXCITE, you should use the following guide.
필요한 것
Place your finger in the small notch on the left corner of the phone.
Use your finger to gently pull up on the back cover where the notch is located.
Gently pull up on the back cover, working around the phone.
Remove the cover from the phone, and set it aside for later installation.
Remove the three 4mm PH00 screws holding the WiFi/GPS antenna in.
Gently pry the WiFi/GPS antenna out using a Jimmy and set aside.
거의 끝나갑니다!
결론
