주요 콘텐츠로 건너뛰기
Alcatel One Touch Elevate (5017B) Motherboard Replacement
필요한 것
  1. Alcatel One Touch Elevate (5017B) Motherboard  Replacement, Battery: 1 단계, 이미지 1/3 Alcatel One Touch Elevate (5017B) Motherboard  Replacement, Battery: 1 단계, 이미지 2/3 Alcatel One Touch Elevate (5017B) Motherboard  Replacement, Battery: 1 단계, 이미지 3/3
    • Locate the small indent on the lower left corner.
    • Use your fingers or a small plastic opening tool to lift the back cover off.
  2. Alcatel One Touch Elevate (5017B) Motherboard  Replacement: 2 단계, 이미지 1/3 Alcatel One Touch Elevate (5017B) Motherboard  Replacement: 2 단계, 이미지 2/3 Alcatel One Touch Elevate (5017B) Motherboard  Replacement: 2 단계, 이미지 3/3
    • Locate the indent between the battery and your phone.
    • Use your finger or a small plastic opening tool to lift the battery free.
  3. Alcatel One Touch Elevate (5017B) Motherboard  Replacement, Motherboard: 3 단계, 이미지 1/3 Alcatel One Touch Elevate (5017B) Motherboard  Replacement, Motherboard: 3 단계, 이미지 2/3 Alcatel One Touch Elevate (5017B) Motherboard  Replacement, Motherboard: 3 단계, 이미지 3/3
    • Using the Phillips screw driver, remove the 9 screws from the phone.
  4. Alcatel One Touch Elevate (5017B) Motherboard  Replacement: 4 단계, 이미지 1/1
    • Using your prying tool, place it between the screen and the back cover and pry it open.
  5. Alcatel One Touch Elevate (5017B) Motherboard  Replacement: 5 단계, 이미지 1/2 Alcatel One Touch Elevate (5017B) Motherboard  Replacement: 5 단계, 이미지 2/2
    • Disconnect the camera from the mother board with your prying tool.
  6. Alcatel One Touch Elevate (5017B) Motherboard  Replacement: 6 단계, 이미지 1/3 Alcatel One Touch Elevate (5017B) Motherboard  Replacement: 6 단계, 이미지 2/3 Alcatel One Touch Elevate (5017B) Motherboard  Replacement: 6 단계, 이미지 3/3
    • Remove both of this cables located on the bottom left corner of the phone.
  7. Alcatel One Touch Elevate (5017B) Motherboard  Replacement: 7 단계, 이미지 1/2 Alcatel One Touch Elevate (5017B) Motherboard  Replacement: 7 단계, 이미지 2/2
    • Remove the volume and power button using your prying tool.
    • Go underneath the bronze plate with your prying tool and carefully pry it off.
  8. Alcatel One Touch Elevate (5017B) Motherboard  Replacement: 8 단계, 이미지 1/1
    • Remove this pice that is to the right of the camera with your prying tool.
  9. Alcatel One Touch Elevate (5017B) Motherboard  Replacement: 9 단계, 이미지 1/2 Alcatel One Touch Elevate (5017B) Motherboard  Replacement: 9 단계, 이미지 2/2
    • Remove this two pieces by using your tweezers.
    • Carefully pull them off. There will be a black flap where you can place your tweezers to pull.
  10. Alcatel One Touch Elevate (5017B) Motherboard  Replacement: 10 단계, 이미지 1/1
    • Using you prying tool, go in-between the phone.
    • Carefully pry it off.
결론
Yahriel Negrete
회원 가입일: 02/08/18
291 평판
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 270
