주요 콘텐츠로 건너뛰기
기기를 수리하세요
수리할 권리
상점
소개
This guide is a prerequisite guide to accessing the internal components of an Alcatel One Touch Evolve 2 phone that need replacing. Be aware that the phone is made of many plastic and electronic parts, so be gentle and diligent when using any force.
  1. Turn off the phone before proceeding with disassembly to prevent shock and potential shorting of any electrical somponents. Remove the back cover using one of the plastic opening tools and the slit in one of the corners. Be gentle when prying so as to not wear out the tool.
    • Turn off the phone before proceeding with disassembly to prevent shock and potential shorting of any electrical somponents.
    • Remove the back cover using one of the plastic opening tools and the slit in one of the corners.
    • Be gentle when prying so as to not wear out the tool.
  2. Remove the battery using one of the plastic opening tools and the dome-shaped indent next to the battery face.
    • Remove the battery using one of the plastic opening tools and the dome-shaped indent next to the battery face.
  3. OPEN ALL THE TABS
    RAM Upgrade Kits for Mac
    키트 쇼핑하기
    Enough RAM
    For All The Tabs
    키트 쇼핑하기
  4. Unscrew the four 4mm JIS screws in each corner using the J000 screwdriver head. Turn the screws counter-clockwise to loosen.
    • Unscrew the four 4mm JIS screws in each corner using the J000 screwdriver head. Turn the screws counter-clockwise to loosen.
  5. Insert a plastic or metal spudger between the front cover and rear frame in one of the areas indicated by the red squares and gently pry the rear frame loose. Repeat the process all the way around the phone until the rear frame comes loose. Insert a plastic or metal spudger between the front cover and rear frame in one of the areas indicated by the red squares and gently pry the rear frame loose. Repeat the process all the way around the phone until the rear frame comes loose. Insert a plastic or metal spudger between the front cover and rear frame in one of the areas indicated by the red squares and gently pry the rear frame loose. Repeat the process all the way around the phone until the rear frame comes loose.
    • Insert a plastic or metal spudger between the front cover and rear frame in one of the areas indicated by the red squares and gently pry the rear frame loose. Repeat the process all the way around the phone until the rear frame comes loose.
  6. Pull the rear frame off with your hands. Pull the rear frame off with your hands.
    • Pull the rear frame off with your hands.
결론
Andrew Bai
회원 가입일: 2017년 01월 30일
634 평판
안내서 5개 작성하였습니다
IUPUI, Team 1-3, Baechle Spring 2017 IUPUI, Team 1-3, Baechle Spring 2017 회원
IUPUI-BAECHLE-S17S1G3
4 회원들
안내서 5개 작성하였습니다
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 734
