소개
This guide will help you in replacing the front camera of an Alcatel One Touch Evolve 2 phone.
필요한 것
Remove the back cover using one of the plastic opening tools and the slit in one of the corners.
Use a plastic opening tool to pop the speaker press-fit connector free.
Slide the edge of the tool under the connector and gently lift up on the edge; the connector should pop free with little force.
다른 3명이 해당 안내서를 완성하였습니다.
