소개
This guide will teach you how to replace the front speaker of the Alcatel OneTouch Evolve 2.
필요한 것
Remove the back cover using one of the plastic opening tools and the slit in one of the corners.
Use a plastic opening tool to pop the speaker press-fit connector free.
Slide the edge of the tool under the connector and gently lift up on the edge; the connector should pop free with little force.
Use a spudger to pry out the speaker from the front panel using the prongs on the speaker.
거의 끝나갑니다!
결론
