주요 콘텐츠로 건너뛰기
Alcatel One Touch Evolve 2 Main Circuit Board Replacement
필요한 것
  1. Alcatel One Touch Evolve 2 Main Circuit Board Replacement, Back Frame: 1 단계, 이미지 3개 중 1개 Alcatel One Touch Evolve 2 Main Circuit Board Replacement, Back Frame: 1 단계, 이미지 3개 중 2개 Alcatel One Touch Evolve 2 Main Circuit Board Replacement, Back Frame: 1 단계, 이미지 3개 중 3개
    • Turn off the phone before proceeding with disassembly to prevent shock and potential shorting of any electrical somponents.
    • Remove the back cover using one of the plastic opening tools and the slit in one of the corners.
    • Be gentle when prying so as to not wear out the tool.
  2. Alcatel One Touch Evolve 2 Main Circuit Board Replacement: 2 단계, 이미지 1개 중 1개
    • Remove the battery using one of the plastic opening tools and the dome-shaped indent next to the battery face.
  3. Alcatel One Touch Evolve 2 Main Circuit Board Replacement: 3 단계, 이미지 1개 중 1개
    • Unscrew the four 4mm JIS screws in each corner using the J000 screwdriver head. Turn the screws counter-clockwise to loosen.
  4. Alcatel One Touch Evolve 2 Main Circuit Board Replacement: 4 단계, 이미지 3개 중 1개 Alcatel One Touch Evolve 2 Main Circuit Board Replacement: 4 단계, 이미지 3개 중 2개 Alcatel One Touch Evolve 2 Main Circuit Board Replacement: 4 단계, 이미지 3개 중 3개
    • Insert a plastic or metal spudger between the front cover and rear frame in one of the areas indicated by the red squares and gently pry the rear frame loose. Repeat the process all the way around the phone until the rear frame comes loose.
  5. Alcatel One Touch Evolve 2 Main Circuit Board Replacement: 5 단계, 이미지 2개 중 1개 Alcatel One Touch Evolve 2 Main Circuit Board Replacement: 5 단계, 이미지 2개 중 2개
    • Pull the rear frame off with your hands.
  6. Alcatel One Touch Evolve 2 Main Circuit Board Replacement, Main Circuit Board: 6 단계, 이미지 2개 중 1개 Alcatel One Touch Evolve 2 Main Circuit Board Replacement, Main Circuit Board: 6 단계, 이미지 2개 중 2개
    • Use a plastic opening tool to pop the speaker press-fit connector free.
    • Slide the edge of the tool under the connector and gently lift up on the edge; the connector should pop free with little force.
  7. Alcatel One Touch Evolve 2 Main Circuit Board Replacement: 7 단계, 이미지 1개 중 1개
    • Use a plastic opening tool to lift the front camera press-fit connector free.
  8. Alcatel One Touch Evolve 2 Main Circuit Board Replacement: 8 단계, 이미지 1개 중 1개
    • Insert one of the plastic opening tools into any side of the main circuit board and gently pry it loose from the front cover. Repeat the process all around the circuit board.
  9. Alcatel One Touch Evolve 2 Main Circuit Board Replacement: 9 단계, 이미지 1개 중 1개
    • Detach the main circuit board from the front cover.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Andrew Bai
회원 가입일: 01/30/17
634 평판
안내서 5개를 작성함
IUPUI, Team 1-3, Baechle Spring 2017 IUPUI, Team 1-3, Baechle Spring 2017 회원
IUPUI-BAECHLE-S17S1G3
4 회원들
안내서 10개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 23
전체 시간: 1,667
