소개
Replacing the camera for the Alcatel One Touch Evolve 2 is a simple process that requires two tools. Be careful, as many of the pieces of this phone are damageable, and diligent, as parts of this phone do tend to prove stubborn.
필요한 것
Take a nylon spudger and pry apart the back plastic casing of the phone. Begin with the gap in the bottom right hand corner, and pry the spudger around the outside of the phone until it dislodges from the body.
Once separated, remove the plastic backing from the phone and set it aside.
Follow the above steps in reverse to reassemble the device.
다른 2명이 해당 안내서를 완성하였습니다.
