주요 콘텐츠로 건너뛰기
Alcatel One Touch Fierce Battery Replacement
필요한 것
  1. Alcatel One Touch Fierce Battery Replacement, Rear Case: 1 단계, 이미지 1/2 Alcatel One Touch Fierce Battery Replacement, Rear Case: 1 단계, 이미지 2/2
    • Pry with a plastic opening tool, or your fingernail, in the divot at the bottom left corner of the phone.
    • Lift the rear case by the corner nearest the divot and remove it from the phone.
  2. Alcatel One Touch Fierce Battery Replacement, Midframe: 2 단계, 이미지 1/3 Alcatel One Touch Fierce Battery Replacement, Midframe: 2 단계, 이미지 2/3 Alcatel One Touch Fierce Battery Replacement, Midframe: 2 단계, 이미지 3/3
    • Remove the 11 Phillips #000 screws.
    • The midframe should lift free.
  3. Alcatel One Touch Fierce Battery Replacement, Battery: 3 단계, 이미지 1/2 Alcatel One Touch Fierce Battery Replacement, Battery: 3 단계, 이미지 2/2
    • Use the tip of a spudger to pull back the yellow tape covering the battery connector.
    • Use a pair of tweezers to pull the battery connector from its port.
    • Be careful not to tear the battery from its connection.
결론
다른 23명이 해당 안내서를 완성하였습니다.
Jonathan Ruiz
회원 가입일: 12/13/11
1,322 평판
안내서 2개 작성하였습니다
댓글 6개
Hello.. please suggest how to remove battery of one touch FLASH.
It is non removable battery.. Since my mobile is unable to reboot I need to remove back cover to make it work
Kapil Chaudhari - 답글
remove sd and sim cards with power off…same as fierce 4/pop 4 all Phillips 000 screws come out then carefully unsnap inner back case half from main case starting on opposite side of power button.with each snap undone, carefully pry case half’s apart using plastic tool or credit card. once apart, unfasten battery connector. power up phone before re assembly.once it works power off and reverse instructions to assemble.
john vanlandingham - 답글
If the battery is so easy to remove, why is it called “non-removable”?
fbanks47 - 답글
how do you reboot after battery replacement
Alan Duncan - 답글
How do I transfer google files from my alcotel phone to my computer
Alan Duncan - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 10
30일 전: 38
전체 시간: 74,586
