주요 콘텐츠로 건너뛰기
기기를 수리하세요
수리할 권리
상점
소개
In this guide you will be shown how to effectively replace the front camera on your device.
  1. Pry with a plastic opening tool, or your fingernail, in the divot at the bottom left corner of the phone. Lift the rear case by the corner nearest the divot and remove it from the phone.
    • Pry with a plastic opening tool, or your fingernail, in the divot at the bottom left corner of the phone.
    • Lift the rear case by the corner nearest the divot and remove it from the phone.
  2. Remove the 11 Phillips #000 screws. The midframe should lift free. The midframe should lift free.
    • Remove the 11 Phillips #000 screws.
    • The midframe should lift free.
  3. OPEN ALL THE TABS
    RAM Upgrade Kits for Mac
    키트 쇼핑하기
    Enough RAM
    For All The Tabs
    키트 쇼핑하기
  4. Use the tip of a spudger to pull back the yellow tape covering the battery connector. Use a pair of tweezers to pull the battery connector from its port.
    • Use the tip of a spudger to pull back the yellow tape covering the battery connector.
    • Use a pair of tweezers to pull the battery connector from its port.
    • Be careful not to tear the battery from its connection.
  5. Carefully remove the motherboard from the rest of the phone.
    • Carefully remove the motherboard from the rest of the phone.
  6. Use a pair of tweezers to disconnect and remove the front facing camera from the motherboard. Use a pair of tweezers to disconnect and remove the front facing camera from the motherboard.
    • Use a pair of tweezers to disconnect and remove the front facing camera from the motherboard.
결론
다른 5명이 해당 안내서를 완성하였습니다.
Rijkaard Thomas
회원 가입일: 2014년 10월 22일
99 평판
안내서 1개 작성함
UMass Dartmouth, Team 5-5, Vijaybhaskar Fall 2014 UMass Dartmouth, Team 5-5, Vijaybhaskar Fall 2014 회원
UMASSD-VIJAYBHASKAR-F14S5G5
3 회원들
안내서 3개 작성하였습니다
tenx tenx tenx !!?
ismail - 답글
I paid for a phone to capture precious moments, & the pictures are horrible, how can this be fixed??? This is wrong on all levels, I feel that we should be able to try any phone out before purchasing, so we know what we are buying, I'm returning my phone & wouldn't recommend this brand to anyone.
Jeanne Edenfield - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 3
전체 시간: 6,350
