주요 콘텐츠로 건너뛰기
Alcatel One Touch Idol 3 Battery Replacement
필요한 것
  1. Alcatel One Touch Idol 3 Battery Replacement, Battery: 1 단계, 이미지 1/3 Alcatel One Touch Idol 3 Battery Replacement, Battery: 1 단계, 이미지 2/3 Alcatel One Touch Idol 3 Battery Replacement, Battery: 1 단계, 이미지 3/3
    • Remove the sim tray by inserting a sim removal tool and then pulling it out.
  2. Alcatel One Touch Idol 3 Battery Replacement: 2 단계, 이미지 1/3 Alcatel One Touch Idol 3 Battery Replacement: 2 단계, 이미지 2/3 Alcatel One Touch Idol 3 Battery Replacement: 2 단계, 이미지 3/3
    • Remove the back cover by moving around its perimeter with a thin object that can fit.
    • Eventually you will be able to pry open the back cover.
    • Although a razor is depicted, we recommend using ESD-safe pry tools instead.
  3. Alcatel One Touch Idol 3 Battery Replacement: 3 단계, 이미지 1/2 Alcatel One Touch Idol 3 Battery Replacement: 3 단계, 이미지 2/2
    • Remove the protective sticker from the battery connection.
  4. Alcatel One Touch Idol 3 Battery Replacement: 4 단계, 이미지 1/2 Alcatel One Touch Idol 3 Battery Replacement: 4 단계, 이미지 2/2
    • Disconnect the battery's connection to the motherboard by lifting it upwards.
  5. Alcatel One Touch Idol 3 Battery Replacement: 5 단계, 이미지 1/2 Alcatel One Touch Idol 3 Battery Replacement: 5 단계, 이미지 2/2
    • Add a small amount of isopropyl alcohol around the sides of the battery to soften the adhesive.
    • Take care to not get isopropyl alcohol on any other parts of the phone.
  6. Alcatel One Touch Idol 3 Battery Replacement: 6 단계, 이미지 1/3 Alcatel One Touch Idol 3 Battery Replacement: 6 단계, 이미지 2/3 Alcatel One Touch Idol 3 Battery Replacement: 6 단계, 이미지 3/3
    • Pry out the battery by leveraging an object under the battery and lifting it upwards.
    • Although a razor is depicted, we recommend using ESD-safe pry tools instead. A razor could easily puncture the battery and create a hazard.
결론
Eric Lopez
회원 가입일: 10/31/23
133 평판
안내서 1개 작성함
CSU Los Angeles, Team 2-87, Briggs Fall 2023 CSU Los Angeles, Team 2-87, Briggs Fall 2023 회원
CSULA-BRIGGS-F23S2G87
1 회원
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 9
전체 시간: 106
