주요 콘텐츠로 건너뛰기
Alcatel OneTouch Elevate SIM Card Replacement
필요한 것
  1. Alcatel OneTouch Elevate SIM Card Replacement, Battery: 1 단계, 이미지 1/3 Alcatel OneTouch Elevate SIM Card Replacement, Battery: 1 단계, 이미지 2/3 Alcatel OneTouch Elevate SIM Card Replacement, Battery: 1 단계, 이미지 3/3
    • Locate the small indent on the lower left corner.
    • Use your fingers or a small plastic opening tool to lift the back cover off.
  2. Alcatel OneTouch Elevate SIM Card Replacement: 2 단계, 이미지 1/3 Alcatel OneTouch Elevate SIM Card Replacement: 2 단계, 이미지 2/3 Alcatel OneTouch Elevate SIM Card Replacement: 2 단계, 이미지 3/3
    • Locate the indent between the battery and your phone.
    • Use your finger or a small plastic opening tool to lift the battery free.
  3. Alcatel OneTouch Elevate SIM Card Replacement, SIM card: 3 단계, 이미지 1/2 Alcatel OneTouch Elevate SIM Card Replacement, SIM card: 3 단계, 이미지 2/2
    • Locate the SIM card slot at the top left of the phone.
    • If an SIM card is not present, you can skip to step 4
  4. Alcatel OneTouch Elevate SIM Card Replacement: 4 단계, 이미지 1/1
    • The SIM card will have an indent at the top, use this to carefully pull the card from the slot.
  5. Alcatel OneTouch Elevate SIM Card Replacement: 5 단계, 이미지 1/2 Alcatel OneTouch Elevate SIM Card Replacement: 5 단계, 이미지 2/2
    • Grab the new SIM card making sure not to touch the metallic area.
    • With the metallic patch facing down, insert the card into the slot.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Jorge
회원 가입일: 02/08/18
165 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 11
30일 전: 25
전체 시간: 480
