이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Locate the small indent on the lower left corner.
Use your fingers or a small plastic opening tool to lift the back cover off.
Locate the indent between the battery and your phone.
Use your finger or a small plastic opening tool to lift the battery free.
Locate the SIM card slot at the top left of the phone.
If an SIM card is not present, you can skip to step 4
The SIM card will have an indent at the top, use this to carefully pull the card from the slot.
Grab the new SIM card making sure not to touch the metallic area.
With the metallic patch facing down, insert the card into the slot.
다른 한 분이 해당 안내서를 완성하였습니다.
