주요 콘텐츠로 건너뛰기
Alcatel OneTouch Evolve Battery Removal
필요한 것
  1. Alcatel OneTouch Evolve Battery Removal, Locate the access tab: 1 단계, 이미지 1/1
    • This will be an opening with enough space to insert the flat head of the plastic opening tool.
    • It will be located on the bottom right of the phone
  2. Alcatel OneTouch Evolve Battery Removal, Place the flat head end of the pry tool into the tab: 2 단계, 이미지 1/3 Alcatel OneTouch Evolve Battery Removal, Place the flat head end of the pry tool into the tab: 2 단계, 이미지 2/3 Alcatel OneTouch Evolve Battery Removal, Place the flat head end of the pry tool into the tab: 2 단계, 이미지 3/3
    • Rotate the pry tool 90 degrees until the panel lifts up.
    • With your thumb nail, lift the rest of the panel up around the perimeter of the phone.
  3. Alcatel OneTouch Evolve Battery Removal, Identify the Battery: 3 단계, 이미지 1/1
    • This is the battery for the Alcatel One Touch Evolve. Look for this component when the back panel has been removed.
  4. Alcatel OneTouch Evolve Battery Removal, Removing the battery: 4 단계, 이미지 1/2 Alcatel OneTouch Evolve Battery Removal, Removing the battery: 4 단계, 이미지 2/2
    • Place finger in the tab on the top right corner of the battery indicated by a black arrow. With slight pressure, push battery down and out of the slot until the battery is removed
결론
다른 12명이 해당 안내서를 완성하였습니다.
Brendan Egan
회원 가입일: 10/28/14
2,467 평판
안내서 5개 작성하였습니다
UMass Dartmouth, Team 4-5, Miles Fall 2014 UMass Dartmouth, Team 4-5, Miles Fall 2014 회원
UMASSD-MILES-F14S4G5
3 회원들
안내서 12개 작성하였습니다
댓글 5개
Thanks 4 the info.
dennisp1964 - 답글
my phone is rooted
next time i,m delete all software
now my phone show only lock screen
how to install my old software
Noushad Marshi - 답글
Thank you very much!
Kath B - 답글
Easy and clear instructions! I am 95 yrs old and I found your instructions wonderful! Thank you Helen Spriggs
Helen Spriggs - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 12
전체 시간: 9,998
