주요 콘텐츠로 건너뛰기
Alcatel OneTouch Pop Icon Interior Back Panel Replacement
필요한 것
  1. Alcatel OneTouch Pop Icon Interior Back Panel Replacement, Battery: 1 단계, 이미지 1/1
    • Shut down the device
    • Flip the phone so that the screen is facing the surface you are working on
    • Aggressive prying may result in damaging the back panel or the internal contents of the phone.
    • Use the plastic opening tool to gently pry off the back panel. There is a small notch in the bottom left corner of the phone that you can use for increased leverage.
  2. Alcatel OneTouch Pop Icon Interior Back Panel Replacement: 2 단계, 이미지 1/2 Alcatel OneTouch Pop Icon Interior Back Panel Replacement: 2 단계, 이미지 2/2
    • Use your thumbnail to lift the battery from the phone.
  3. Alcatel OneTouch Pop Icon Interior Back Panel Replacement, Interior Back Panel: 3 단계, 이미지 1/1
    • Using the J000 Phillips screwdriver, remove the twelve silver 3mm screws.
    • Using the J000 Phillips screwdriver, remove the one green 3mm screw.
  4. Alcatel OneTouch Pop Icon Interior Back Panel Replacement: 4 단계, 이미지 1/1
    • With the screen facing you and the front facing camera to your right, insert the plastic opening tool between the screen and the interior back panel and gently pry it off.
    • Make sure all of the clips come undone when you pry the seam loose.
결론
John Halsey
회원 가입일: 04/01/16
1,000 평판
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 4
30일 전: 6
전체 시간: 665
