주요 콘텐츠로 건너뛰기
Alcatel POP C9 OT7047 Touch Screen Glass Digitizer Replacement
필요한 것
동영상 개요
  1. Alcatel POP C9 OT7047 Touch Screen Glass Digitizer Replacement, Battery Cover Removal: 1 단계, 이미지 1/3 Alcatel POP C9 OT7047 Touch Screen Glass Digitizer Replacement, Battery Cover Removal: 1 단계, 이미지 2/3 Alcatel POP C9 OT7047 Touch Screen Glass Digitizer Replacement, Battery Cover Removal: 1 단계, 이미지 3/3
    • The Battery / Back cover is secured to the main frame by plastic clips.
    • Use a plastic tool to remove it.
  2. Alcatel POP C9 OT7047 Touch Screen Glass Digitizer Replacement, Battery Disconnecting 1: 2 단계, 이미지 1/3 Alcatel POP C9 OT7047 Touch Screen Glass Digitizer Replacement, Battery Disconnecting 1: 2 단계, 이미지 2/3 Alcatel POP C9 OT7047 Touch Screen Glass Digitizer Replacement, Battery Disconnecting 1: 2 단계, 이미지 3/3
    • Use a Phillips screwdriver and remove the two screws secured the battery connector shield.
    • With tweezers careful remove the battery connector shield.
  3. Alcatel POP C9 OT7047 Touch Screen Glass Digitizer Replacement, Battery Disconnecting 2: 3 단계, 이미지 1/1
    • Disconnect the battery cable.
  4. Alcatel POP C9 OT7047 Touch Screen Glass Digitizer Replacement, Main Board removal 1: 4 단계, 이미지 1/2 Alcatel POP C9 OT7047 Touch Screen Glass Digitizer Replacement, Main Board removal 1: 4 단계, 이미지 2/2
    • Disconnect:
    • Touchscreen flex cable
    • Main Camera flex cable
    • LCD flex cable
    • Vibra-motor
    • New line.Remove 7x Phillips screws.
  5. Alcatel POP C9 OT7047 Touch Screen Glass Digitizer Replacement: 5 단계, 이미지 1/3 Alcatel POP C9 OT7047 Touch Screen Glass Digitizer Replacement: 5 단계, 이미지 2/3 Alcatel POP C9 OT7047 Touch Screen Glass Digitizer Replacement: 5 단계, 이미지 3/3
    • Careful unstuck the Volume buttons flex cable and the Power button flex cable.
    • Use a plastic tool and remove the Logic board.
  6. Alcatel POP C9 OT7047 Touch Screen Glass Digitizer Replacement, Touch screen glass removal: 6 단계, 이미지 1/3 Alcatel POP C9 OT7047 Touch Screen Glass Digitizer Replacement, Touch screen glass removal: 6 단계, 이미지 2/3 Alcatel POP C9 OT7047 Touch Screen Glass Digitizer Replacement, Touch screen glass removal: 6 단계, 이미지 3/3
    • Use a hair dryer to warm the glass to soften the adhesive.
    • Use a knife or tool with a sharp edge and start the separating the glass from the frame.
    • Continue with a plastic tool.
  7. Alcatel POP C9 OT7047 Touch Screen Glass Digitizer Replacement: 7 단계, 이미지 1/3 Alcatel POP C9 OT7047 Touch Screen Glass Digitizer Replacement: 7 단계, 이미지 2/3 Alcatel POP C9 OT7047 Touch Screen Glass Digitizer Replacement: 7 단계, 이미지 3/3
    • Insert wisdom here.
  8. Alcatel POP C9 OT7047 Touch Screen Glass Digitizer Replacement: 8 단계, 이미지 1/3 Alcatel POP C9 OT7047 Touch Screen Glass Digitizer Replacement: 8 단계, 이미지 2/3 Alcatel POP C9 OT7047 Touch Screen Glass Digitizer Replacement: 8 단계, 이미지 3/3
    • Clean the frame and install a new adhesive tape.
    • Install the touch screen.
결론
ZFix
회원 가입일: 12/09/13
191,308 평판
안내서 330개 작성하였습니다
Master Techs Master Techs 회원
Community
322 회원들
안내서 2,535개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 3
전체 시간: 1,727
