소개
A faulty touch screen display assembly can result in your phone's touch screen being unresponsive. Get help replacing it here.
필요한 것
Take off the case by flipping the phone over and wedging your finger in the notch on the bottom edge. Pry up until you hear the clicking and the edge releases. Continue to pry the case up, moving around the perimeter of the phone.
It should pop off in various places around the perimeter of the phone, and then come off easily.
Turn the phone so the top is facing you. The board the USB charging port is attached to is on the bottom.
Disconnect the other side of the outer orange ribbon cable by locating the socket terminal at the base of the phone and prying it up using the blue spudger.
Turn the phone so the volume buttons are facing you.
Disconnect the orange ribbon cables from the motherboard. Flip the black switches with the blue spudger.
Gently pull the ribbons away from the clamp by lifting them away from the connection with the blue spudger. It should release and hang loose.
Gently pry and lift out the earpiece speaker. Pry from the upper side of the speaker rather than the bottom.
다른 한 분이 해당 안내서를 완성하였습니다.
