주요 콘텐츠로 건너뛰기
Alcatel Pop 4 Plus Speaker Replacement
필요한 것
  1. Alcatel Pop 4 Plus Speaker Replacement, Battery: 1 단계, 이미지 1/2 Alcatel Pop 4 Plus Speaker Replacement, Battery: 1 단계, 이미지 2/2
    • Remove the back cover by sliding your fingernail in the grove around the edge of the phone and prying it off.
  2. Alcatel Pop 4 Plus Speaker Replacement: 2 단계, 이미지 1/2 Alcatel Pop 4 Plus Speaker Replacement: 2 단계, 이미지 2/2
    • Remove seventeen 3mm Phillips #000 screws from the mid-frame.
  3. Alcatel Pop 4 Plus Speaker Replacement: 3 단계, 이미지 1/1
    • Use the flat end of the spudger, or your fingernail, to pry off the mid-frame.
  4. Alcatel Pop 4 Plus Speaker Replacement: 4 단계, 이미지 1/2 Alcatel Pop 4 Plus Speaker Replacement: 4 단계, 이미지 2/2
    • Use the flat end of the spudger disconnect the battery from the motherboard.
    • Use the flat end of the spudger tool to pry out the battery.
  5. Alcatel Pop 4 Plus Speaker Replacement, Speaker: 5 단계, 이미지 1/2 Alcatel Pop 4 Plus Speaker Replacement, Speaker: 5 단계, 이미지 2/2
    • Use a spudger to pry the speaker from the mid-frame.
결론
Maalik Poleon
회원 가입일: 01/25/18
202 평판
안내서 2개 작성하였습니다
USF Tampa, Team S20-G6, Passmore Spring 2018 USF Tampa, Team S20-G6, Passmore Spring 2018 회원
USFT-PASSMORE-S18S20G6
4 회원들
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 5
30일 전: 7
전체 시간: 334
