주요 콘텐츠로 건너뛰기
Alienware 15 M.2 Solid State Drive
필요한 것
    • After turning the computer off, close the display and turn the computer over.
  1. Alienware 15 M.2 Solid State Drive, Remove the Back Panel Screws and Lift: 2 단계, 이미지 1개 중 1개
    • After the computer base (#1) is facing up, use a Philips screwdriver to remove the two captive screws (#2) which hold the base panel (#3) down.
    • Then, use a spudger (#4) to lift up the panel. You can also use your fingernail to lift it as well.
    • After the front has been lifted up a bit, the non-screw side of the panel will need to be slid forward a little to finish lifting out the base panel from the computer.
  2. Alienware 15 M.2 Solid State Drive, Optional: Disconnect the Battery: 3 단계, 이미지 1개 중 1개
    • You don't need to disconnect the laptop's battery if you are only replacing the back panel: only perform this step if you will be handling or replacing the electrical components of the computer.
    • Disconnect the battery cable from the system board by pulling up on the battery connector (#1).
    • Turn the computer back over and open the display to the point where you can press the power button.
    • Press and hold the power button for 4 seconds to ground the system board so that you can safely remove components such as the RAM.
  3. Alienware 15 M.2 Solid State Drive, Remove Solid-State screw: 4 단계, 이미지 1개 중 1개
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before Working Inside Your Computer. After working inside your computer, follow the instructions in After Working Inside Your Computer.
    • CAUTION : Solid-state drives are fragile. Exercise care when handling the solid-state drives, and avoid touching the gold contact pins.
    • CAUTION : To avoid data loss, do not remove the solid-state drive while the computer is in sleep or on state.
    • Remove the screw that secures the solid-state drive to the computer base.
  4. Alienware 15 M.2 Solid State Drive, Slide the Solid-State Drive: 5 단계, 이미지 1개 중 1개
    • Slide and remove the solid-state drive from the solid-state drive slot.
  5. Alienware 15 M.2 Solid State Drive, Slide the Solid-state Drive: 6 단계, 이미지 1개 중 1개
    • Slide the solid-state drive into the solid-state drive slot.
  6. Alienware 15 M.2 Solid State Drive, Align the screw: 7 단계, 이미지 1개 중 1개
    • Align the screw hole on the solid-state drive with the screw hole on the computer base.
  7. Alienware 15 M.2 Solid State Drive, Replace the Screw: 8 단계, 이미지 1개 중 1개
    • Replace the screw that secures the solid-state drive to the computer base.
결론
To reassemble your device, screw the base panel on again.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Johnathan Hammond
회원 가입일: 02/28/18
45,582 평판
안내서 408개를 작성함
RampUP America, Inc. RampUP America, Inc. 회원
Community
43 회원들
안내서 1,996개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 3
지난 30일: 8
전체 시간: 493
