이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
After turning the computer off, close the display and turn the computer over.
After the computer base (#1) is facing up, use a Philips screwdriver to remove the two captive screws (#2) which hold the base panel (#3) down.
Then, use a spudger (#4) to lift up the panel. You can also use your fingernail to lift it as well.
After the front has been lifted up a bit, the non-screw side of the panel will need to be slid forward a little to finish lifting out the base panel from the computer.
Disconnect the battery cable from the system board by pulling up on the battery connector (#1).
Turn the computer back over and open the display to the point where you can press the power button.
Press and hold the power button for 4 seconds to ground the system board so that you can safely remove components such as the RAM.
Remove the screw that secures the solid-state drive to the computer base.
Slide and remove the solid-state drive from the solid-state drive slot.
Align the screw hole on the solid-state drive with the screw hole on the computer base.
Replace the screw that secures the solid-state drive to the computer base.
다른 한 분이 해당 안내서를 완성하였습니다.
