주요 콘텐츠로 건너뛰기
Alienware 15 R2 Fan Replacement
필요한 것
  1. Alienware 15 R2 Fan Replacement, RAM: 1 단계, 이미지 1/3 Alienware 15 R2 Fan Replacement, RAM: 1 단계, 이미지 2/3 Alienware 15 R2 Fan Replacement, RAM: 1 단계, 이미지 3/3
    • Place laptop upside down with the hinge facing you, then remove the two 9mm Phillips #0 screws located in the bottom left and right of the of the rear panel.
    • Remove the rear panel by using the iFixit opening tool to separate it from the back of the laptop.
  2. Alienware 15 R2 Fan Replacement: 2 단계, 이미지 1/2 Alienware 15 R2 Fan Replacement: 2 단계, 이미지 2/2
    • Use the iFixit opening tool to disconnect the battery cable. Put the iFixit tool underneath the cable and then pull it to remove.
  3. Alienware 15 R2 Fan Replacement: 3 단계, 이미지 1/2 Alienware 15 R2 Fan Replacement: 3 단계, 이미지 2/2
    • Find the RAM located near the edge of the computer closest to you. Locate the small latches on either side of the RAM stick and push in the two latches to release. Gently grasp the RAM stick on either side and pull straight out. Repeat for the second RAM stick.
  4. Alienware 15 R2 Fan Replacement, Fan: 4 단계, 이미지 1/2 Alienware 15 R2 Fan Replacement, Fan: 4 단계, 이미지 2/2
    • In the center of the RAM card, remove the 9 mm screw using the Phillips #0 screwdriver.
  5. Alienware 15 R2 Fan Replacement: 5 단계, 이미지 1/2 Alienware 15 R2 Fan Replacement: 5 단계, 이미지 2/2
    • Remove all screws from the back casing. (4X 18mm, 4X 10mm, 4X 6mm)
    • Press your finger in the hole next to the hard drive to lift the keyboard up.
  6. Alienware 15 R2 Fan Replacement: 6 단계, 이미지 1/1
    • Disconnect the fan wires.
  7. Alienware 15 R2 Fan Replacement: 7 단계, 이미지 1/3 Alienware 15 R2 Fan Replacement: 7 단계, 이미지 2/3 Alienware 15 R2 Fan Replacement: 7 단계, 이미지 3/3
    • If you're replacing the fans, remove the three 6.0 mm screws from the fan and pull the fans out. (The orange circle shows where a screw will already be removed). If you're cleaning the fans, use compressed air to clean the blades and air duct.
결론
Nathaniel Evans
회원 가입일: 09/18/19
429 평판
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 9
30일 전: 36
전체 시간: 2,637
