주요 콘텐츠로 건너뛰기
Alienware 15 R3 Hard Drive Replacement
필요한 것
  1. Alienware 15 R3  Hard Drive Replacement, Hard Drive: 1 단계, 이미지 1/3 Alienware 15 R3  Hard Drive Replacement, Hard Drive: 1 단계, 이미지 2/3 Alienware 15 R3  Hard Drive Replacement, Hard Drive: 1 단계, 이미지 3/3
    • Find Power in start menu and click Shut Down to turn off your Alienware 15 R3.
    • Wait a few seconds until all the lights around are off.
    • Unplug the power supply.
  2. Alienware 15 R3  Hard Drive Replacement: 2 단계, 이미지 1/3 Alienware 15 R3  Hard Drive Replacement: 2 단계, 이미지 2/3 Alienware 15 R3  Hard Drive Replacement: 2 단계, 이미지 3/3
    • Remove the seven M2.5x13 screws from the base cover.
    • Remove the base cover carefully.
    • Save these screws for later.
    • The screw on the top middle of base cover cannot be removed after unscrewing. But it is okay to remove the base cover.
  3. Alienware 15 R3  Hard Drive Replacement: 3 단계, 이미지 1/3 Alienware 15 R3  Hard Drive Replacement: 3 단계, 이미지 2/3 Alienware 15 R3  Hard Drive Replacement: 3 단계, 이미지 3/3
    • Remove the two M3x3 screws that are holding the bracket and one M2.5x8 screw holding the hard drive assembly .
  4. Alienware 15 R3  Hard Drive Replacement: 4 단계, 이미지 1/2 Alienware 15 R3  Hard Drive Replacement: 4 단계, 이미지 2/2
    • Put bottom plate back on your laptop and secure the bottom plate with the screws removed previously.
    • Prior to reassembly, clean the dust on fans as circled in picture if needed.
  5. Alienware 15 R3  Hard Drive Replacement: 5 단계, 이미지 1/1
    • Your Alienware 15 R3 is ready to roll.
결론
By removing the HDD from the laptop, BSOD will never happen again when you boot the laptop. Please note that, the storage space than it was in the past.
다른 한 분이 해당 안내서를 완성하였습니다.
Yutong Yin
회원 가입일: 05/10/21
145 평판
안내서 1개 작성함
York University, Team S1-G1, O'Regan Fall 2021 York University, Team S1-G1, O'Regan Fall 2021 회원
YORK-O'REGAN-F21S1G1
1 회원
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 20
전체 시간: 1,294
