주요 콘텐츠로 건너뛰기
Alienware 17 R2 Screen Replacement
필요한 것
  1. Alienware 17 R2  Screen Replacement, Display: 1 단계, 이미지 1/1
    • Put the laptop on a hard surface.
    • Make sure that the Alienware is not plugged into any power source.
    • First, we need to unplug the battery.
  2. Alienware 17 R2  Screen Replacement: 2 단계, 이미지 1/2 Alienware 17 R2  Screen Replacement: 2 단계, 이미지 2/2
    • To unplug the battery, turn the computer upside down.
    • Remove the two 4mm screws from the plastic covering protecting the inner part of the laptop.
  3. Alienware 17 R2  Screen Replacement: 3 단계, 이미지 1/2 Alienware 17 R2  Screen Replacement: 3 단계, 이미지 2/2
    • Gently, pull the cover up and slide it off.
  4. Alienware 17 R2  Screen Replacement: 4 단계, 이미지 1/3 Alienware 17 R2  Screen Replacement: 4 단계, 이미지 2/3 Alienware 17 R2  Screen Replacement: 4 단계, 이미지 3/3
    • Now, you are going to look for a yellow tag.
    • Unplug the black wire that has the yellow tag.
    • This with successfully disconnect your battery.
  5. Alienware 17 R2  Screen Replacement: 5 단계, 이미지 1/2 Alienware 17 R2  Screen Replacement: 5 단계, 이미지 2/2
    • Using the plastic opening tool, gently remove the black plastic casing from the LCD screen.
    • Run the opening tool along the inner side of the computer where the screen and the plastic covering meet.
  6. Alienware 17 R2  Screen Replacement: 6 단계, 이미지 1/1
    • No you will unscrew the 2mm screws on the top and bottom side of the screen.
  7. Alienware 17 R2  Screen Replacement: 7 단계, 이미지 1/1
    • Tilt the screen forward towards the keyboard.
    • Disconnect the plug that is connecting the screen to the main body.
  8. Alienware 17 R2  Screen Replacement: 8 단계, 이미지 1/1
    • Gently, lift the display away from the laptop.
결론
Luis Garcia
회원 가입일: 09/20/17
402 평판
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 9
전체 시간: 3,081
