주요 콘텐츠로 건너뛰기
기기를 수리하세요
수리할 권리
상점
소개
This guide will outline the replacement of the battery on an Alienware 17 R2 laptop, if your laptop will not hold a charge/turn on without being connected to the charger. Replacing the battery on your laptop might help you fix this problem. To get started please prepare a Phillips #0 Screwdriver. This is not a permanent solution. If the laptop has been used for two or three years, it is recommended to buy a new one rather than replace the battery, due to outdated hardware, battery controllers, etc.
부품
지정된 부품이 없습니다.
  1. Unplug the laptop from the power adapter.
    • Unplug the laptop from the power adapter.
    • Be sure the laptop is turned off.
    • Place the laptop face down on a hard surface.
  2. Remove the two screws on the access door. Pull up the access door and slide off. Pull up the access door and slide off.
    • Remove the two screws on the access door.
    • Pull up the access door and slide off.
  3. Look for the black wire with the yellow tag. Carefully unplug the black cord with the yellow tag. This will successfully disconnect the battery.
    • Look for the black wire with the yellow tag.
    • Carefully unplug the black cord with the yellow tag.
    • This will successfully disconnect the battery.
  4. Disconnect the four cables from the motherboard as shown in the picture.
    • Disconnect the four cables from the motherboard as shown in the picture.
    • Be careful when disconnecting the cables. Their connectors are very fragile and if too much force is applied, they can come out of the PCB, causing permanent damage.
  5. Unscrew the  palm-rest screws Remove the two 2.5mm x 18mm screws from the top as shown in  picture 1. Remove the two 2.5mm x 10mm screws from the left side, remove the left top side 2.5mm x 18mm screw.  Remove the other two 2.5mm x 10mm screws from the right side  and remove the right top side 2.5mm x18mm screw as shown in picture 2.
    • Unscrew the palm-rest screws
    • Remove the two 2.5mm x 18mm screws from the top as shown in picture 1.
    • Remove the two 2.5mm x 10mm screws from the left side, remove the left top side 2.5mm x 18mm screw. Remove the other two 2.5mm x 10mm screws from the right side and remove the right top side 2.5mm x18mm screw as shown in picture 2.
    • Remove the eight 2.5mm x 8mm screws from the middle as shown in picture 3.
  6. Slowly separate the palm-rest from the laptop. Disconnect the power cord from the laptop to the palm-rest as shown in the picture 2. Remove the palm-rest.
    • Slowly separate the palm-rest from the laptop.
    • Disconnect the power cord from the laptop to the palm-rest as shown in the picture 2.
    • Remove the palm-rest.
  7. Unplug the  two cables from the laptop as shown in the picture
    • Unplug the two cables from the laptop as shown in the picture
  8. Remove the six 2.5mm x 5mm screws as shown in picture 1. Gently lift up and remove the battery Gently lift up and remove the battery
    • Remove the six 2.5mm x 5mm screws as shown in picture 1.
    • Gently lift up and remove the battery
결론
To reassemble your computer, follow these instructions in reverse order.
다른 3명이 해당 안내서를 완성하였습니다.
Luis Garcia
회원 가입일: 2017년 09월 20일
402 평판
안내서 4개 작성하였습니다
Many thanks for a decent write up. My only observation was that I don't know why there was a need to unplug the power to the palm rest and fully remove it? You have access to the battery once the palm rest is lifted. Good write up non the less
mark dale - 답글
I agree with Mark. No need to unplug the cable to the palm rest.
lrshapiro -
댓글 쓰기
조회 통계:
24 시간 전: 6
7일 전: 52
30일 전: 173
전체 시간: 5,666
