주요 콘텐츠로 건너뛰기
Alienware 17 R2 Hard Drive Replacement
필요한 것
  1. Alienware 17 R2 Hard Drive Replacement, Hard Drive: 1 단계, 이미지 1/1
    • Make sure the laptop is unplugged from any power source.
    • Put the laptop facing down on a hard surface.
  2. Alienware 17 R2 Hard Drive Replacement: 2 단계, 이미지 1/3 Alienware 17 R2 Hard Drive Replacement: 2 단계, 이미지 2/3 Alienware 17 R2 Hard Drive Replacement: 2 단계, 이미지 3/3
    • Unscrew the two 6mm screws on the bottom side of the laptop.
    • Lift up the back cover and slide towards you.
  3. Alienware 17 R2 Hard Drive Replacement: 3 단계, 이미지 1/2 Alienware 17 R2 Hard Drive Replacement: 3 단계, 이미지 2/2
    • Locate the Hard Drive
  4. Alienware 17 R2 Hard Drive Replacement: 4 단계, 이미지 1/1
    • Remove the screws that connect the SSD Bay to the laptop
  5. Alienware 17 R2 Hard Drive Replacement: 5 단계, 이미지 1/1
    • Unscrew the three screws holding the hard drive
  6. Alienware 17 R2 Hard Drive Replacement: 6 단계, 이미지 1/2 Alienware 17 R2 Hard Drive Replacement: 6 단계, 이미지 2/2
    • Unscrew the four screws on the long sides of the hard drive casing
  7. Alienware 17 R2 Hard Drive Replacement: 7 단계, 이미지 1/3 Alienware 17 R2 Hard Drive Replacement: 7 단계, 이미지 2/3 Alienware 17 R2 Hard Drive Replacement: 7 단계, 이미지 3/3
    • Now that the hard drive casing is off, carefully unplug the hard drive from the laptop
    • Your hard drive has now been successfully removed from your device
결론
Luis Garcia
회원 가입일: 09/20/17
402 평판
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 15
전체 시간: 1,483
