주요 콘텐츠로 건너뛰기
기기를 수리하세요
수리할 권리
상점
부품
지정된 부품이 없습니다.
  1. WARNING :  Before working inside your computer, read the  safety information that shipped with your computer and  follow the steps in Before Working Inside Your Computer.  After working inside your computer, follow the instructions  in After Working Inside Your Computer. Make sure the base panel is removed. Make sure the palm rest is removed too.
    • WARNING : Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before Working Inside Your Computer. After working inside your computer, follow the instructions in After Working Inside Your Computer.
    • Make sure the base panel is removed.
    • Make sure the palm rest is removed too.
    • Lift the latches and disconnect the touch-pad cable and the status-light cable from the power-button board.
  2. Disconnect the power-button cable from the power-button board. Disconnect the power-button cable from the power-button board.
    • Disconnect the power-button cable from the power-button board.
    • Remove the screws that secure the power-button board to the palm-rest assembly.
    • Lift the power-button board off the palm-rest assembly.
    • Align the screw holes on the power-button board with the screw holes on the palm-rest assembly.
    • Replace the screws that secure the power-button board to the palm-rest assembly.
    • Connect the power-button board cable to the power-button board.
    • Slide the touch-pad cable and the status-light cable into their respective connectors on the power-button board and press down the latches to secure the cables.
결론
Terrence15
회원 가입일: 2017년 12월 18일
72,934 평판
안내서 442개 작성하였습니다
Informative Technologies Inc. Informative Technologies Inc. 회원
Community
32 회원들
안내서 1,933개 작성하였습니다
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 3
전체 시간: 241
