주요 콘텐츠로 건너뛰기
Alienware 17 R3 Display Replacement
필요한 것
  1. Alienware 17 R3 Display Replacement, Display: 1 단계, 이미지 1/1
    이 단계에 사용된 도구:
    Anti-Static Wrist Strap
    $7.95
    구매
    • Turn the computer off.
    • Disconnect the charging cable from the computer.
    • Failure to unplug the charging cable could result in damaging the computer or seriously injuring yourself.
    • Flip the computer upside down.
    • Wear the anti-static wrist strap to prevent any electrical shock to the components. Shocks may damage the components.
  2. Alienware 17 R3 Display Replacement: 2 단계, 이미지 1/1
    • Unscrew and remove the two 4mm Phillips screws from cover.
  3. Alienware 17 R3 Display Replacement: 3 단계, 이미지 1/1
    • Pull up and slide cover off.
  4. Alienware 17 R3 Display Replacement: 4 단계, 이미지 1/2 Alienware 17 R3 Display Replacement: 4 단계, 이미지 2/2
    • Unplug the black wire with the yellow tag to disconnect the battery.
  5. Alienware 17 R3 Display Replacement: 5 단계, 이미지 1/1
    • Using the plastic opening tool, pull display casing away from main body.
  6. Alienware 17 R3 Display Replacement: 6 단계, 이미지 1/1
    • Unscrew and remove the two 2mm Phillips screws from the bottom of the display.
  7. Alienware 17 R3 Display Replacement: 7 단계, 이미지 1/1
    • Disconnect plugs connecting the display to the main body.
  8. Alienware 17 R3 Display Replacement: 8 단계, 이미지 1/1
    • Lift display out.
결론
다른 6명이 해당 안내서를 완성하였습니다.
Jonathon Tschurwald
회원 가입일: 02/01/17
845 평판
안내서 4개 작성하였습니다
UW Tacoma, Team 1-1, Rose Winter 2017 UW Tacoma, Team 1-1, Rose Winter 2017 회원
UWT-ROSE-W17S1G1
3 회원들
안내서 5개 작성하였습니다
댓글 한 개
The best and easiest way to replace the screen!
Jhun Calvin - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 8
30일 전: 20
전체 시간: 4,294
