주요 콘텐츠로 건너뛰기
Alienware 17 R4 Plastic Cover Replacement
필요한 것
  1. Alienware 17 R4 Plastic Cover Replacement, Base Cover: 1 단계, 이미지 1개 중 1개
    • Use a PH1 screwdriver bit to remove the six M2.5x13 screws (2.4 mm) on the back of the laptop.
    • Use a PH1 screwdriver bit to loosen the one M2x3 screw (1.9 mm).
    • The M2x3 screw (1.9 mm) does not come out completely.
  2. Alienware 17 R4 Plastic Cover Replacement: 2 단계, 이미지 2개 중 1개 Alienware 17 R4 Plastic Cover Replacement: 2 단계, 이미지 2개 중 2개
    • Pull the base cover up to remove it.
    • If you are having trouble, insert a plastic opening tool into the divots along the laptop's edges to loosen.
    • Removing the cover may require some force.
  3. Alienware 17 R4 Plastic Cover Replacement, Hard Disk Drive (HDD): 3 단계, 이미지 3개 중 1개 Alienware 17 R4 Plastic Cover Replacement, Hard Disk Drive (HDD): 3 단계, 이미지 3개 중 2개 Alienware 17 R4 Plastic Cover Replacement, Hard Disk Drive (HDD): 3 단계, 이미지 3개 중 3개
    • Disconnect the battery connector cable, located on the right side of the laptop, above the hard disk drive.
    • Once you have removed the cable, wait 5-10 minutes to allow the laptop to power down.
    • Failure to remove the battery connector cable properly may damage other parts of the laptop.
  4. Alienware 17 R4 Plastic Cover Replacement: 4 단계, 이미지 3개 중 1개 Alienware 17 R4 Plastic Cover Replacement: 4 단계, 이미지 3개 중 2개 Alienware 17 R4 Plastic Cover Replacement: 4 단계, 이미지 3개 중 3개
    • Use a PH1 screwdriver bit to remove the four M2.5x5 screws (2.4 mm) on the hard disk drive.
  5. Alienware 17 R4 Plastic Cover Replacement: 5 단계, 이미지 3개 중 1개 Alienware 17 R4 Plastic Cover Replacement: 5 단계, 이미지 3개 중 2개 Alienware 17 R4 Plastic Cover Replacement: 5 단계, 이미지 3개 중 3개
    • Gently lift the HDD cable to disconnect it from the laptop.
  6. Alienware 17 R4 Plastic Cover Replacement: 6 단계, 이미지 2개 중 1개 Alienware 17 R4 Plastic Cover Replacement: 6 단계, 이미지 2개 중 2개
    • Pull the hard drive up to remove.
  7. Alienware 17 R4 Plastic Cover Replacement, RAM: 7 단계, 이미지 3개 중 1개 Alienware 17 R4 Plastic Cover Replacement, RAM: 7 단계, 이미지 3개 중 2개 Alienware 17 R4 Plastic Cover Replacement, RAM: 7 단계, 이미지 3개 중 3개
    • Move the metal sidings outward to release the RAM card.
  8. Alienware 17 R4 Plastic Cover Replacement: 8 단계, 이미지 1개 중 1개
    • Slide the RAM card out towards yourself to remove it.
    • Repeat the same step for the RAM card above.
    • Slide the RAM card out carefully to avoid damaging it.
  9. Alienware 17 R4 Plastic Cover Replacement, Wi-Fi card: 9 단계, 이미지 1개 중 1개
    • Locate the WI-FI card.
  10. Alienware 17 R4 Plastic Cover Replacement: 10 단계, 이미지 2개 중 1개 Alienware 17 R4 Plastic Cover Replacement: 10 단계, 이미지 2개 중 2개
    • Peel back plastic cover of wi-fi card.
    • Use a PH1 screwdriver bit and remove the one M2x3 screw (1.9 mm)
  11. Alienware 17 R4 Plastic Cover Replacement: 11 단계, 이미지 3개 중 1개 Alienware 17 R4 Plastic Cover Replacement: 11 단계, 이미지 3개 중 2개 Alienware 17 R4 Plastic Cover Replacement: 11 단계, 이미지 3개 중 3개
    • Gently undo the clips attached to the wi-fi card.
    • If the clip is not gently removed it is possible that the entire base will be torn off the wi-fi card. You will need to purchase a new wi-fi card if this occurs.
  12. Alienware 17 R4 Plastic Cover Replacement: 12 단계, 이미지 2개 중 1개 Alienware 17 R4 Plastic Cover Replacement: 12 단계, 이미지 2개 중 2개
    • Locate the cables that connect the wi-fi card.
    • Gently pull upwards to remove cables and slide the wi-fi card out from its slot.
  13. Alienware 17 R4 Plastic Cover Replacement, Solid State Drive: 13 단계, 이미지 2개 중 1개 Alienware 17 R4 Plastic Cover Replacement, Solid State Drive: 13 단계, 이미지 2개 중 2개
    • Remove the one M2x3 screw (1.9 mm) using a PH1 screwdriver bit
  14. Alienware 17 R4 Plastic Cover Replacement: 14 단계, 이미지 2개 중 1개 Alienware 17 R4 Plastic Cover Replacement: 14 단계, 이미지 2개 중 2개
    • Slide the solid state drive towards yourself to prevent damage to the card.
  15. Alienware 17 R4 Plastic Cover Replacement, Fan Shroud: 15 단계, 이미지 3개 중 1개 Alienware 17 R4 Plastic Cover Replacement, Fan Shroud: 15 단계, 이미지 3개 중 2개 Alienware 17 R4 Plastic Cover Replacement, Fan Shroud: 15 단계, 이미지 3개 중 3개
    • Remove the two M2.5x7 screws (2.44 mm) located on the rear panel using a PH1 screwdriver bit.
  16. Alienware 17 R4 Plastic Cover Replacement: 16 단계, 이미지 2개 중 1개 Alienware 17 R4 Plastic Cover Replacement: 16 단계, 이미지 2개 중 2개
    • Insert the plastic opening tool under the fan shroud to slowly lift it up.
    • Repeat process on the middle and opposite side.
  17. Alienware 17 R4 Plastic Cover Replacement: 17 단계, 이미지 2개 중 1개 Alienware 17 R4 Plastic Cover Replacement: 17 단계, 이미지 2개 중 2개
    • Firmly lift the plastic opening tool and pull the fan shroud towards you.
    • This will take a large amount of force and will not come out easily the first time.
    • Careful not to tear out the piece causing damage to the fan shroud
  18. Alienware 17 R4 Plastic Cover Replacement, Plastic Cover: 18 단계, 이미지 3개 중 1개 Alienware 17 R4 Plastic Cover Replacement, Plastic Cover: 18 단계, 이미지 3개 중 2개 Alienware 17 R4 Plastic Cover Replacement, Plastic Cover: 18 단계, 이미지 3개 중 3개
    • Unscrew the two M2x3 screws (1.9 mm) at the top right and top left of the laptop that hold the tron lights in place.
  19. Alienware 17 R4 Plastic Cover Replacement: 19 단계, 이미지 2개 중 1개 Alienware 17 R4 Plastic Cover Replacement: 19 단계, 이미지 2개 중 2개
    • Follow the wiring to unplug the tron lights.
  20. Alienware 17 R4 Plastic Cover Replacement: 20 단계, 이미지 3개 중 1개 Alienware 17 R4 Plastic Cover Replacement: 20 단계, 이미지 3개 중 2개 Alienware 17 R4 Plastic Cover Replacement: 20 단계, 이미지 3개 중 3개
    • Remove the fourteen M2.5XL8' screws (2.4 mm) located in the plastic cover using the PH1 screwdriver.
  21. Alienware 17 R4 Plastic Cover Replacement: 21 단계, 이미지 1개 중 1개
    • Use the plastic opening tool to gently lift the sides of the cover.
  22. Alienware 17 R4 Plastic Cover Replacement: 22 단계, 이미지 2개 중 1개 Alienware 17 R4 Plastic Cover Replacement: 22 단계, 이미지 2개 중 2개
    • Slowly lift up the plastic cover.
결론
작성자
6다른 기여자 명과 함께
Hector Mendez III
회원 가입일: 09/11/17
1,340 평판
안내서 8개를 작성함
CSU Fullerton, Team S2-G4, Bruce Fall 2017 CSU Fullerton, Team S2-G4, Bruce Fall 2017 회원
CSUF-BRUCE-F17S2G4
4 회원들
안내서 9개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 12
전체 시간: 3,738
