주요 콘텐츠로 건너뛰기
Alienware 17 R4 Solid State Drive (SSD) Replacement
필요한 것
  1. Alienware 17 R4 Solid State Drive (SSD) Replacement, Base Cover: 1 단계, 이미지 1개 중 1개
    • Use a PH1 screwdriver bit to remove the six M2.5x13 screws (2.4 mm) on the back of the laptop.
    • Use a PH1 screwdriver bit to loosen the one M2x3 screw (1.9 mm).
    • The M2x3 screw (1.9 mm) does not come out completely.
  2. Alienware 17 R4 Solid State Drive (SSD) Replacement: 2 단계, 이미지 2개 중 1개 Alienware 17 R4 Solid State Drive (SSD) Replacement: 2 단계, 이미지 2개 중 2개
    • Pull the base cover up to remove it.
    • If you are having trouble, insert a plastic opening tool into the divots along the laptop's edges to loosen.
    • Removing the cover may require some force.
  3. Alienware 17 R4 Solid State Drive (SSD) Replacement, Hard Disk Drive (HDD): 3 단계, 이미지 3개 중 1개 Alienware 17 R4 Solid State Drive (SSD) Replacement, Hard Disk Drive (HDD): 3 단계, 이미지 3개 중 2개 Alienware 17 R4 Solid State Drive (SSD) Replacement, Hard Disk Drive (HDD): 3 단계, 이미지 3개 중 3개
    • Disconnect the battery connector cable, located on the right side of the laptop, above the hard disk drive.
    • Once you have removed the cable, wait 5-10 minutes to allow the laptop to power down.
    • Failure to remove the battery connector cable properly may damage other parts of the laptop.
  4. Alienware 17 R4 Solid State Drive (SSD) Replacement: 4 단계, 이미지 3개 중 1개 Alienware 17 R4 Solid State Drive (SSD) Replacement: 4 단계, 이미지 3개 중 2개 Alienware 17 R4 Solid State Drive (SSD) Replacement: 4 단계, 이미지 3개 중 3개
    • Use a PH1 screwdriver bit to remove the four M2.5x5 screws (2.4 mm) on the hard disk drive.
  5. Alienware 17 R4 Solid State Drive (SSD) Replacement: 5 단계, 이미지 3개 중 1개 Alienware 17 R4 Solid State Drive (SSD) Replacement: 5 단계, 이미지 3개 중 2개 Alienware 17 R4 Solid State Drive (SSD) Replacement: 5 단계, 이미지 3개 중 3개
    • Gently lift the HDD cable to disconnect it from the laptop.
  6. Alienware 17 R4 Solid State Drive (SSD) Replacement: 6 단계, 이미지 2개 중 1개 Alienware 17 R4 Solid State Drive (SSD) Replacement: 6 단계, 이미지 2개 중 2개
    • Pull the hard drive up to remove.
  7. Alienware 17 R4 Solid State Drive (SSD) Replacement, Solid State Drive: 7 단계, 이미지 2개 중 1개 Alienware 17 R4 Solid State Drive (SSD) Replacement, Solid State Drive: 7 단계, 이미지 2개 중 2개
    • Remove the one M2x3 screw (1.9 mm) using a PH1 screwdriver bit
  8. Alienware 17 R4 Solid State Drive (SSD) Replacement: 8 단계, 이미지 2개 중 1개 Alienware 17 R4 Solid State Drive (SSD) Replacement: 8 단계, 이미지 2개 중 2개
    • Slide the solid state drive towards yourself to prevent damage to the card.
결론
다른 3명이 해당 안내서를 완성하였습니다.
작성자
6다른 기여자 명과 함께
Hector Mendez III
회원 가입일: 09/11/17
1,340 평판
안내서 8개를 작성함
CSU Fullerton, Team S2-G4, Bruce Fall 2017 CSU Fullerton, Team S2-G4, Bruce Fall 2017 회원
CSUF-BRUCE-F17S2G4
4 회원들
안내서 9개를 작성함
댓글 한 개
Is it advised to pull the HDD before pulling the SSD or is this guide just written in a way to cover how to remove both of them?
John Crooks - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 7
지난 30일: 28
전체 시간: 7,029
