주요 콘텐츠로 건너뛰기
Alienware 17 R4 Wi-Fi Card Replacement
필요한 것
  1. Alienware 17 R4 Wi-Fi Card Replacement, Base Cover: 1 단계, 이미지 1개 중 1개
    • Use a PH1 screwdriver bit to remove the six M2.5x13 screws (2.4 mm) on the back of the laptop.
    • Use a PH1 screwdriver bit to loosen the one M2x3 screw (1.9 mm).
    • The M2x3 screw (1.9 mm) does not come out completely.
  2. Alienware 17 R4 Wi-Fi Card Replacement: 2 단계, 이미지 2개 중 1개 Alienware 17 R4 Wi-Fi Card Replacement: 2 단계, 이미지 2개 중 2개
    • Pull the base cover up to remove it.
    • If you are having trouble, insert a plastic opening tool into the divots along the laptop's edges to loosen.
    • Removing the cover may require some force.
  3. Alienware 17 R4 Wi-Fi Card Replacement, Wi-Fi card: 3 단계, 이미지 1개 중 1개
    • Locate the WI-FI card.
  4. Alienware 17 R4 Wi-Fi Card Replacement: 4 단계, 이미지 2개 중 1개 Alienware 17 R4 Wi-Fi Card Replacement: 4 단계, 이미지 2개 중 2개
    • Peel back plastic cover of wi-fi card.
    • Use a PH1 screwdriver bit and remove the one M2x3 screw (1.9 mm)
  5. Alienware 17 R4 Wi-Fi Card Replacement: 5 단계, 이미지 3개 중 1개 Alienware 17 R4 Wi-Fi Card Replacement: 5 단계, 이미지 3개 중 2개 Alienware 17 R4 Wi-Fi Card Replacement: 5 단계, 이미지 3개 중 3개
    • Gently undo the clips attached to the wi-fi card.
    • If the clip is not gently removed it is possible that the entire base will be torn off the wi-fi card. You will need to purchase a new wi-fi card if this occurs.
  6. Alienware 17 R4 Wi-Fi Card Replacement: 6 단계, 이미지 2개 중 1개 Alienware 17 R4 Wi-Fi Card Replacement: 6 단계, 이미지 2개 중 2개
    • Locate the cables that connect the wi-fi card.
    • Gently pull upwards to remove cables and slide the wi-fi card out from its slot.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
6다른 기여자 명과 함께
Hector Mendez III
회원 가입일: 09/11/17
1,340 평판
안내서 8개를 작성함
CSU Fullerton, Team S2-G4, Bruce Fall 2017 CSU Fullerton, Team S2-G4, Bruce Fall 2017 회원
CSUF-BRUCE-F17S2G4
4 회원들
안내서 9개를 작성함
댓글 한 개
What is the logic for removing the HHD prior to removing the WIFI card?
Roderick Vanderzalm - 답글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 13
지난 30일: 38
전체 시간: 5,083
