주요 콘텐츠로 건너뛰기
Alienware Area-51m battery Replacement
필요한 것
  1. Alienware Area-51m battery Replacement, battery: 1 단계, 이미지 1/3 Alienware Area-51m battery Replacement, battery: 1 단계, 이미지 2/3 Alienware Area-51m battery Replacement, battery: 1 단계, 이미지 3/3
    • turn off the laptop and remove all the cable connect to your laptop.
    • Place the back of the laptop up.
    • Remove 6 M2.5X8 computer base screws on the baseplate.
  2. Alienware Area-51m battery Replacement: 2 단계, 이미지 1/3 Alienware Area-51m battery Replacement: 2 단계, 이미지 2/3 Alienware Area-51m battery Replacement: 2 단계, 이미지 3/3
    • this is how it looks like when you take off the baseplate.
    • remove the cable connect with battery and main board.
    • Remove all 6 M2.5X5 battery screws around the battery.
  3. Alienware Area-51m battery Replacement: 3 단계, 이미지 1/2 Alienware Area-51m battery Replacement: 3 단계, 이미지 2/2
    • take off the battery and use your new battery to instead.
    • this is how it looks like when you take off the battery(for some reason i take off the hard disk as well, you don't need to care about that.)
  4. Alienware Area-51m battery Replacement: 4 단계, 이미지 1/3 Alienware Area-51m battery Replacement: 4 단계, 이미지 2/3 Alienware Area-51m battery Replacement: 4 단계, 이미지 3/3
    • now you just need to put everything back.And do not forget to put the screws back also.
결론
When reassembling your device, follow the instructions in reverse order.
yupeng ge
회원 가입일: 01/20/21
1 평판
안내서 1개 작성함
York University, Team S1-G10, O'Regan Winter 2021 York University, Team S1-G10, O'Regan Winter 2021 회원
YORK-O'REGAN-W21S1G10
1 회원
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 8
30일 전: 38
전체 시간: 1,494
