이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
turn off the laptop and remove all the cable connect to your laptop.
Place the back of the laptop up.
Remove 6 M2.5X8 computer base screws on the baseplate.
this is how it looks like when you take off the baseplate.
remove the cable connect with battery and main board.
Remove all 6 M2.5X5 battery screws around the battery.
take off the battery and use your new battery to instead.
this is how it looks like when you take off the battery(for some reason i take off the hard disk as well, you don't need to care about that.)
now you just need to put everything back.And do not forget to put the screws back also.
