주요 콘텐츠로 건너뛰기
Alienware Aurora M9700 Hard Drive Replacement
필요한 것
  1. Alienware Aurora M9700 Hard Drive Replacement, Hard Drive: 1 단계, 이미지 1개 중 1개
    • Turn laptop upside down so you're looking at the bottom side of the laptop.
  2. Alienware Aurora M9700 Hard Drive Replacement: 2 단계, 이미지 3개 중 1개 Alienware Aurora M9700 Hard Drive Replacement: 2 단계, 이미지 3개 중 2개 Alienware Aurora M9700 Hard Drive Replacement: 2 단계, 이미지 3개 중 3개
    • At the bottom left corner, locate the square battery pack with the sliding unlock emblem above it.
    • Slide the lock to the right to unlock the battery pack.
    • Once it's unlocked the battery will release.
    • Lift the battery, removing it from its compartment.
  3. Alienware Aurora M9700 Hard Drive Replacement: 3 단계, 이미지 3개 중 1개 Alienware Aurora M9700 Hard Drive Replacement: 3 단계, 이미지 3개 중 2개 Alienware Aurora M9700 Hard Drive Replacement: 3 단계, 이미지 3개 중 3개
    • At the bottom right corner, locate the two hard drives labeled 1 and 2.
    • Remove the screws located on top of the hard drives slots.
    • Once screws are removed from each hard drive, slide both hard drives out of the slot.
  4. Alienware Aurora M9700 Hard Drive Replacement: 4 단계, 이미지 3개 중 1개 Alienware Aurora M9700 Hard Drive Replacement: 4 단계, 이미지 3개 중 2개 Alienware Aurora M9700 Hard Drive Replacement: 4 단계, 이미지 3개 중 3개
    • Each hard drive is attached to a cover which contains 4 screws located on all 4 corners of the hard drive.
    • Remove each of the 4 screws on both hard drive covers.
    • Once both covers are removed only the original hard drive will remain.
  5. Alienware Aurora M9700 Hard Drive Replacement: 5 단계, 이미지 3개 중 1개 Alienware Aurora M9700 Hard Drive Replacement: 5 단계, 이미지 3개 중 2개 Alienware Aurora M9700 Hard Drive Replacement: 5 단계, 이미지 3개 중 3개
    • Secure the new hard drive to the original hard drive cover, insert the screws on all 4 corners of the hard drive cover.
    • Complete this process for both hard drives. (Optional: if installing two drives.)
결론
작성자
4다른 기여자 명과 함께
Jasmine Anchondo
회원 가입일: 10/09/18
679 평판
안내서 5개를 작성함
Sam Houston State, Team S15-G3, Blackburne Fall 2018 Sam Houston State, Team S15-G3, Blackburne Fall 2018 회원
SHSU-BLACKBURNE-F18S15G3
4 회원들
안내서 5개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 4
전체 시간: 531
