주요 콘텐츠로 건너뛰기
Alienware Aurora M9700 RAM Replacement
필요한 것
  1. Alienware Aurora M9700 RAM Replacement, RAM: 1 단계, 이미지 1/1
    • Turn the laptop over so the bottom of the device is facing upward.
  2. Alienware Aurora M9700 RAM Replacement: 2 단계, 이미지 1/3 Alienware Aurora M9700 RAM Replacement: 2 단계, 이미지 2/3 Alienware Aurora M9700 RAM Replacement: 2 단계, 이미지 3/3
    • Remove the battery by unlocking the lock.
  3. Alienware Aurora M9700 RAM Replacement: 3 단계, 이미지 1/3 Alienware Aurora M9700 RAM Replacement: 3 단계, 이미지 2/3 Alienware Aurora M9700 RAM Replacement: 3 단계, 이미지 3/3
    • Located on the top right corner, find the 4 screws that are holding the back plate to the laptop.
    • Once the screws are removed insert the spudger on the right side and pry upwards to lift the plate to remove the plate.
  4. Alienware Aurora M9700 RAM Replacement: 4 단계, 이미지 1/3 Alienware Aurora M9700 RAM Replacement: 4 단계, 이미지 2/3 Alienware Aurora M9700 RAM Replacement: 4 단계, 이미지 3/3
    • Lift the back plate of the laptop to expose the RAM.
    • Locate the RAM near the bottom edge of the top portion.
  5. Alienware Aurora M9700 RAM Replacement: 5 단계, 이미지 1/3 Alienware Aurora M9700 RAM Replacement: 5 단계, 이미지 2/3 Alienware Aurora M9700 RAM Replacement: 5 단계, 이미지 3/3
    • The RAM is secured by two aluminum locks on each side.
    • Pull the left-lock to the left to release the RAM.
    • While still holding the left hinge, pull the right-lock to the right and the RAM will be released.
  6. Alienware Aurora M9700 RAM Replacement: 6 단계, 이미지 1/3 Alienware Aurora M9700 RAM Replacement: 6 단계, 이미지 2/3 Alienware Aurora M9700 RAM Replacement: 6 단계, 이미지 3/3
    • Once the RAM is released, pull the RAM out.
    • There may be a second RAM located below the first one, if so repeat step 5.
    • After both RAMS are removed you can now replace or upgrade the RAM.
결론
Jasmine Anchondo
회원 가입일: 10/09/18
679 평판
안내서 5개 작성하였습니다
Sam Houston State, Team S15-G3, Blackburne Fall 2018 Sam Houston State, Team S15-G3, Blackburne Fall 2018 회원
SHSU-BLACKBURNE-F18S15G3
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 17
전체 시간: 312
