소개
In this guide, we will be showing you how to remove and replace the Display Assembly.
필요한 것
Loosen the two captive screws that secure the hard-drive assembly to the computer base.
Using the pull-tab, pull the hard-drive assembly to disconnect the hard-drive assembly from the connector on the system board.
Remove the four screws that secure the hard drive to the hard-drive bracket.
Replace the four screws that secure the hard-drive to the hard-drive bracket.
Use the pull-tab to push the hard drive assembly and connect it to the connector on the system board.
Tighten the two captive screws that secure the hard-drive assembly to the computer base.
다른 2명이 해당 안내서를 완성하였습니다.
