이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
소개
In this guide, we will be showing you how to remove and replace the Memory Module.
필요한 것
Use your fingertips to carefully spread apart the securing clips on each end of the memory module connector until the memory module pops up.
Align the notch in the NEW memory module with the tab in the memory module connector.
Slide the memory module firmly into the slot at a 45-degree angle, and press the memory module down until it clicks into place. If you do not hear the click, remove the memory module and reinstall it.
다른 2명이 해당 안내서를 완성하였습니다.
