주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Alienware M11x Power-Button Board Replacement
필요한 것
  1. Alienware M11x Power-Button Board Replacement, Removing the Screws: 1 단계, 이미지 1개 중 1개
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer.
    • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on your computer).
    • Remove the two screws that secure the power button board to the palm rest assembly.
  2. Alienware M11x Power-Button Board Replacement, Lifting the Power Button Board: 2 단계, 이미지 1개 중 1개
    • Lift the power button board off the palm rest assembly.
  3. Alienware M11x Power-Button Board Replacement, Removing the Screws: 3 단계, 이미지 1개 중 1개
    • Place the power button board on the palm rest assembly and replace the two screws that secure the power button board to the palm rest assembly.
    • CAUTION: Before turning on the computer, replace all screws and ensure that no stray screws remain inside the computer. Failure to do so may result in damage the computer.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
darrius
회원 가입일: 03/26/18
5,213 평판
안내서 30개를 작성함
RampUP America, Inc. RampUP America, Inc. 회원
Community
44 회원들
안내서 1,997개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 9
지난 30일: 23
전체 시간: 592
