주요 콘텐츠로 건너뛰기
Alienware M11xR2 Base Cover Replacement
필요한 것
  1. Alienware M11xR2 Base Cover Replacement, Removing the Base Cover: 1 단계, 이미지 1개 중 1개
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer.
    • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on your computer).
    • Turn the computer over.
  2. Alienware M11xR2 Base Cover Replacement, Loosen the Screws: 2 단계, 이미지 1개 중 1개
    • Loosen the eight captive screws that secure the base cover to the computer base.
  3. Alienware M11xR2 Base Cover Replacement, Lifting the Base Cover: 3 단계, 이미지 1개 중 1개
    • Lift the base cover off the computer base.
  4. Alienware M11xR2 Base Cover Replacement, Replacing the Base Cover: 4 단계, 이미지 1개 중 1개
    • Align the tabs on the NEW base cover with the slots on the computer base and place the base cover in position.
  5. Alienware M11xR2 Base Cover Replacement, Securing the Screws: 5 단계, 이미지 1개 중 1개
    • Tighten the eight screws that secure the base cover to the computer base.
결승점
다른 2명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
darrius
회원 가입일: 03/26/18
5,213 평판
안내서 30개를 작성함
RampUP America, Inc. RampUP America, Inc. 회원
Community
43 회원들
안내서 1,985개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 1
전체 시간: 288
