주요 콘텐츠로 건너뛰기
Alienware M11xR2 Battery Pack Replacement
필요한 것
  1. Alienware M11xR2 Battery Pack Replacement, Removing the Base Cover: 1 단계, 이미지 1/1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer.
    • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on your computer).
    • Turn the computer over.
  2. Alienware M11xR2 Battery Pack Replacement, Loosen the Screws: 2 단계, 이미지 1/1
    • Loosen the eight captive screws that secure the base cover to the computer base.
  3. Alienware M11xR2 Battery Pack Replacement, Lifting the Base Cover: 3 단계, 이미지 1/1
    • Lift the base cover off the computer base.
  4. Alienware M11xR2 Battery Pack Replacement, Replacing the Base Cover: 4 단계, 이미지 1/1
    • Align the tabs on the NEW base cover with the slots on the computer base and place the base cover in position.
  5. Alienware M11xR2 Battery Pack Replacement, Securing the Screws: 5 단계, 이미지 1/1
    • Tighten the eight screws that secure the base cover to the computer base.
  6. Alienware M11xR2 Battery Pack Replacement, Removing Screws: 6 단계, 이미지 1/1
    • Remove the two screws that secure the battery pack to the computer base.
  7. Alienware M11xR2 Battery Pack Replacement, Disconnecting cable: 7 단계, 이미지 1/1
    • Disconnect the battery pack cable from the connector on the system board.
  8. Alienware M11xR2 Battery Pack Replacement, Lifting Battery Pack: 8 단계, 이미지 1/1
    • Using the pull-tab, lift the battery pack off the computer base.
  9. Alienware M11xR2 Battery Pack Replacement, Placing New Battery Pack: 9 단계, 이미지 1/1
    • Place the NEW battery pack in the battery bay and replace the two screws that secure the battery pack to the computer base.
  10. Alienware M11xR2 Battery Pack Replacement, Routing Battery Pack: 10 단계, 이미지 1/1
    • Route the battery pack cable in the routing guide
  11. Alienware M11xR2 Battery Pack Replacement, Connnecting Battery Pack: 11 단계, 이미지 1/1
    • Connect the battery pack cable to the connector on the system board.
결승점
다른 3명이 해당 안내서를 완성하였습니다.
darrius
회원 가입일: 03/26/18
5,213 평판
안내서 30개 작성하였습니다
RampUP America, Inc. RampUP America, Inc. 회원
Community
42 회원들
안내서 1,984개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 7
전체 시간: 206
