주요 콘텐츠로 건너뛰기
Alienware M11xR2 Coin-Cell Battery Replacement
필요한 것
  1. Alienware M11xR2 Coin-Cell Battery Replacement, Removing the Base Cover: 1 단계, 이미지 1/1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer.
    • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on your computer).
    • Turn the computer over.
  2. Alienware M11xR2 Coin-Cell Battery Replacement, Loosen the Screws: 2 단계, 이미지 1/1
    • Loosen the eight captive screws that secure the base cover to the computer base.
  3. Alienware M11xR2 Coin-Cell Battery Replacement, Lifting the Base Cover: 3 단계, 이미지 1/1
    • Lift the base cover off the computer base.
  4. Alienware M11xR2 Coin-Cell Battery Replacement, Replacing the Base Cover: 4 단계, 이미지 1/1
    • Align the tabs on the NEW base cover with the slots on the computer base and place the base cover in position.
  5. Alienware M11xR2 Coin-Cell Battery Replacement, Securing the Screws: 5 단계, 이미지 1/1
    • Tighten the eight screws that secure the base cover to the computer base.
  6. Alienware M11xR2 Coin-Cell Battery Replacement, Disconnecting Coin-Cell Battery: 6 단계, 이미지 1/1
    • Disconnect the coin-cell battery cable from the connector on the system board.
  7. Alienware M11xR2 Coin-Cell Battery Replacement, Prying The Coin-Cell Battery: 7 단계, 이미지 1/1
    • The coin-cell battery is glued to the system board. Using a plastic scribe, pry the coin-cell battery from the system board.
  8. Alienware M11xR2 Coin-Cell Battery Replacement, Placing New Coin-Cell Battery: 8 단계, 이미지 1/1
    • Use the adhesive on NEW the coin-cell battery and adhere it to the system board.
  9. Alienware M11xR2 Coin-Cell Battery Replacement, Connecting Cable: 9 단계, 이미지 1/1
    • Connect the coin-cell battery cable to the connector on the system board.
결론
다른 3명이 해당 안내서를 완성하였습니다.
darrius
회원 가입일: 03/26/18
5,213 평판
안내서 30개 작성하였습니다
RampUP America, Inc. RampUP America, Inc. 회원
Community
42 회원들
안내서 1,984개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 6
전체 시간: 354
