이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Loosen the eight captive screws that secure the base cover to the computer base.
Align the tabs on the NEW base cover with the slots on the computer base and place the base cover in position.
Tighten the eight screws that secure the base cover to the computer base.
Disconnect the coin-cell battery cable from the connector on the system board.
The coin-cell battery is glued to the system board. Using a plastic scribe, pry the coin-cell battery from the system board.
Use the adhesive on NEW the coin-cell battery and adhere it to the system board.
Connect the coin-cell battery cable to the connector on the system board.
다른 3명이 해당 안내서를 완성하였습니다.
